Results 1 to 3 of 3
Thread: Mercury V6 overheating sensor
08-21-2002, 02:24 PM #1Supporting Vendor
- May 2001
- Maryville, Tn.
- 383
What is the nominal temp these things close at ?
Dave Hensley
08-21-2002, 02:41 PM #27000 RPM
- Houston Tx
- 2,286
190*
I am pretty sure it is 190 the same as the OMC's but I am going thru the books to make sure
08-21-2002, 04:55 PM #3
Temperature Senders
Some of the pre-90s 2.0 and 2.4L had a 190 degree or a 240 degree sender. The 240 degree sender was installed in the center of the head below #1 spark plug hole. The 190 degree sender was installed in the outer side of the head. See pic. Not sure about the "Late Model" senders. 190 sounds right though.
Wayne
