Results 1 to 2 of 2
Thread: Hardin Logs
05-12-2009, 10:11 AM #1
Hardin Logs
I am replacing the gaskets for my Hardin (Logs)exhaust. I noticed that the washers were aluminum and in very poor shape. So, a couple questions:
1. Are they supposed to be aluminum to protect the manifold?
A. If yes, Will copper work just as well?
1a. If not copper, where the heck do I get Aluminum ones?
2. Or will standard washer work fine?
The more I think about this , the more I am thinking regular washers would apply even pressure to the manifold when tightened.......
Maybe the washers I took off were just low grade material and the previous owner just kept tightening them and the result was deformed washers...........Last edited by ASURFCAT; 05-12-2009 at 12:21 PM.
05-13-2009, 05:46 PM #2
Think the alum washers are for sealing but also alum is a sacrificial metal... Copper may not work in your app...? Alum washers can be found at some hardware stores but most likely ordered from a reg nut/bolt place or a Marine dealer...?
