Results 1 to 7 of 7
Thread: prop question on my mirage
05-10-2009, 08:09 PM #1
i am running a 200 carb merc on a 18' mirage ski racer heavy layup. 8 inch set back , bob low water pickup with a extremely fat ear 14 3/4 X 30 pitch chopper. turning it 6200 and running 94 mph. currently running 1 click over the bottom.
questions::
How much higher can i go up on the jackplate?
Will my cle run different then my bobs as far as height in the jack plate?
Should i cut my prop down to a 14 1/2 X 30?
I wanna get more rpm and run a little more mph. Very happy with it now but i would like to push 100 mph. Thanks for the help.... Eric B.1995 mirage jaguar w/ 200 merc....96mph @ 7300 rpm...... sold
1991 Allison XB2002, 1996 225 Promax...... sold
1998 Rocket DC w/ 2020 Yamaha Sho flashed
05-12-2009, 05:04 PM #2
Ive got allmost the same setup 200 efi/6' set back/28 round ear/mid lay up level with pad at 6900 rpm at 89.9 mph I tryed lifting the motor 1/4 and the boat started steping out.wheres the rev limeter set at.
05-12-2009, 05:43 PM #3
I am 2 inches further back so from what I am hearing I can go 3/4 above bottom safely. 6" back I would 1/2 above the bottom. The rev limiter on mine was 5800 but I did away with that system and went to a 16 amp system. ( no limiter)
05-12-2009, 08:40 PM #4
By my self I can go higher but when i put someone else in the boat it starts to step out your numbers look good.Start raising the motor and watch your water presure.I think your going to need some more HP if you want the 100mph club be carefull.
05-12-2009, 08:54 PM #5
I have a few more tricks up my sleeve. Wish me luck. I'll repost next week with my final results. Eric B.
05-13-2009, 07:27 AM #6
Is your motor stock besides the rev lim removed,let me know how it goes I want to try a 30 prop
05-13-2009, 08:58 AM #7
Call me next time out, I'll bring the camera. I am NOT riding with you though, I have a 2 digit backside LOL
11-20 -08 1980 14' Allison
2018 Carbon Fiber 15' Allison
homemade 15" 90 Yamaha
nice and quick 7900 rpm
Happiest driver on the board. Chris Carlson reeds are the way to go. CCM
http://www.youtube.com/watch?v=KQyBn...er_profilepage
