Results 1 to 2 of 2
05-07-2009, 09:16 AM #1Junior Member
- Jan 2009
- Buffalo
- 12
Glastron CVX20 Timing/Carb Questions
Just had some questions hopefully someone can answer. What should the timing be set at.. eveything is stock on a Ford 460BB W/ a Holley carb. And and On the carb it only has one vaccum line coming from the valve cover to the bottom of the carb. Thats it. Is tha Normal?
05-07-2009, 07:36 PM #2
sounds good
vacuum sounds right, nothing smaller going to distrributor? try 12 degrees at idle and maybe 14 its all variable according to what you have, ultimately i like it advanced as much as possible with no spark knock but this can be tough on starters and starting, new stuff is all adjustable for startup
