Results 1 to 8 of 8
Thread: headder question
05-06-2009, 10:09 PM #1
headder question
does anyone run dragster headers on their jet? i have an old rusted out pair of bassets and want to replace them with a set of stainless dragster headders. am i headded in the wrong direction?
05-07-2009, 07:01 AM #2
We have a couple of guys up here on the North Left coast that use the muffled Borla Drag headers (the ones that com back and up at about a 45* angle). They seem to work and give a totally different look
05-07-2009, 12:01 PM #35000 RPM
- Mar 2009
- TENN
- 211
i have seen them run dry also, but usually in very limited use boats. if there is going to be rear seat passengers i feel the dry headers will be like a bar be que grill in the back seat. seriously in my opinion you really need the water injected pipes. every application is different explore some more as i have seen the dry ones actually melt and warp the hulls, good luck but be careful .
05-07-2009, 06:51 PM #4
heat shields
you will need heat shields to protect the boat and the people
05-07-2009, 08:15 PM #5
05-07-2009, 08:16 PM #6
boater mike is the 455 going to be usable?
05-07-2009, 08:49 PM #7
i think so havent looked it over much
the heads look fine and im i know my bottom end is fine . gonna compare cams and probably only buy the things i must buy to put it back together.
05-08-2009, 07:34 AM #85000 RPM
- Jan 2006
- macon GA
- 824
