Results 1 to 4 of 4
05-06-2009, 07:49 PM #1New Member
- May 2009
- long island ny
my project needs some help superboat
i have a 24' superboat jetboat no motor thats oki will build one. the guy before me tryed to cut the bottom plate that the jet bolts on to in the boat i know i have to reglass that area. allso one of the fins are broken can that plate be replaced? should i cut it the rest of the way out? i mite have to find the right man for the job if i can get the part.
05-06-2009, 11:35 PM #2
welcome
welcome to s&f
05-07-2009, 12:17 PM #35000 RPM
- Mar 2009
- TENN
- 211
yes the intake can be repaired but because of the heat to heliarc it it will be needed to remove it from the hull. you may find a used intake for less money, pm me with the part number on the intake i probably have some used ones. if i understand the question, i would not remove the fins from the bottom as this helps load the pump and is intergal for straight line steering control.
05-09-2009, 07:55 PM #4Member
- Nov 2008
- Stevens Point
- 97
Check your PM's I sent you some information
