Results 1 to 5 of 5
Thread: Easiest way to remove a VRO
04-21-2009, 05:28 PM #1
My friend wants to remove the VRO from his Johnson and put a low pressure lift pump in. What is the easiest way to go about this?
Thanks in advance
Ray
04-21-2009, 06:19 PM #2
Is the fuel pump bad? If he just wants to get rid of the oil injection I would just plug the oil line side of the pump and let it pump only fuel. If he wants to replace the whole pump to get rid of it he just has to disconnect the pump and remove it, plug the pulse fitting going into the block and plumb in the new electric pump with a fuel pressure of around 3 to 5 psi.
Ralph Musser
27' Fountain Fever W/ 525SC
22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
24' Triton 240 Gold W/ Mercury 60
14' Royalcraft W/ Evinrude 75 father/daughter project
04-21-2009, 08:48 PM #3
The fuel pump went bad. He also wants to remove the oil injection.
Ray
04-21-2009, 09:10 PM #4
Then just remove it and plug the pulse fitting going to the block and hook up your electric pump.
Ralph Musser
04-21-2009, 09:29 PM #5
that sounds easy enough. Just wanted to make sure.
Thanks
