Results 1 to 8 of 8
Thread: Tach Not Working
03-24-2009, 01:40 PM #1
Tach Not Working
Does It Get A Signal From Under Flywheel, And How Can You Check If Its Coming Out Of There. The Tack Signal Lead Wire Is Grey Going Into Harness Into Boat And Hits A Yellow W A Strip Coming Out Of Harness Coming From Under Flywheel Would I Need To Change Stator Or Rotor If No Signal?? 1982 2.0 Merc 150. Thnks
90 Vegas 89 200 78mph
03-24-2009, 03:14 PM #26000 RPM
- Jul 2003
- Muskoka, Ontario
- 1,061
Most likely the rectifier is gone. It is a little black box with three terminal post on it.
The grey tach wire should be on one of the post.
It is a cheap part and merc used it on many of the motors.
03-25-2009, 10:25 AM #3
Update
THE TACH WILL NOT WORK WITH THE GREY LEAD ON THE CENTER TERMINAL OF THE LITTLE SQAURE CUBE. GUESS THATS THE RECTIFIER. I GOT TO GET A SERVICE MANUAL. IS IT EASY TO CHRECK TIMING? I HAVE A AUTOMOTIVE TIMING LIGHT
03-25-2009, 10:38 AM #4
Jay Smith
DID SEARCH FOUND SOMETHING FROM JAYTHNKS JAY,
03-25-2009, 10:38 AM #5
Here are the pages ouit of the manual. Precedure han't changed. Just have different specs. Hope this helps.
James Perry
03-25-2009, 11:21 AM #6
I Printed It Thanks Wrechin2
03-25-2009, 11:25 AM #7
No problem. That 82 should not have any stabilizers. Just skip the oil system stuff. Just make sure to check the pointer with a dial indicator. No telling who has moved it. Hate to see you set it at what you think is 22* and it be 30*!!!!!! On the front of the air box it should have what to set the timing at.
James Perry
03-30-2009, 06:24 PM #8Member
- Feb 2006
- St. Petersburg, FL
- 36
Troubleshooting Tach
I need a little help diagnosing a tach problem. How do you measure the signal coming out of regulator through the grey wire? Is it measured as voltage, amps or what? The starboard tach stopped working so I hooked up the grey wire from the port engine and it works. That eliminates the tach as the culprit. I've run diagnostic tests on the stator, trigger, and rev-limiter. All check out. So, it has to be either the regulator or the wring has a short somewhere. How do I check the signal from the regulator? This is on a V-6 Merc; the water-cooled type regulator.
