Results 1 to 15 of 47
Thread: 454 runs like crap
02-03-2009, 09:13 PM #1
454 runs like crap
I need some help getting my 454 to run decent, it idles like crap and is very hard to start even when warm, then bogs most times when I hit the gas and pops like crazy I know the sound isnt the greatest. heres a video link
Ps dont worry about the exhaust I will get some stainless made up when i get some extra cash
http://www.youtube.com/watch?v=S_sqe...e=channel_page
thanks
02-03-2009, 09:18 PM #2
02-03-2009, 09:30 PM #3
I think its a 1992 its got about 10 hrs on it from what im told. I ran great last fall before i put it in the boat, the first time i started it in the boat it ran decent too, it ran good for about 15 min then it started to run like it is in the video, Ill take the carb apart and clean it tommrow and also take the tank out and clean that while im at it. Its not popping through the carb, just the exhaust
02-03-2009, 09:37 PM #4
first thing i would do is pull a leak down test after i checked for water in the fuel
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
02-03-2009, 09:37 PM #5
check your plug wires and then your timing you may have gotten some of that white crap on the ground in it too........
also did you drain all the water out of it the last time??? if not yo may have an issue ARF knows nothing about....like a frozen block which isn't good
02-03-2009, 09:41 PM #6
now wait a min i know frozen its up by you lol
for sale
02-03-2009, 09:53 PM #7
yeah i drained the block then chaised it with rv antifreeze, its in the heated shop at work right now.. im trying to get it warmed up and dried out so i can work on it. Yeah its definatly cold out we had a high temp of 12 today talk about a heat wave compaird to the last couple of weeks
02-04-2009, 12:11 AM #8
sounds like a fuel issue. but it could also be timing just retime it rebuild carb and make sure that its getting atiquit fuel
02-04-2009, 06:48 AM #9
It does not sound like a carb issue from the video. It sounds to consistent. Pull your rocker covers and look for a bent pushrod on the exhaust valves. 454's are notorious for that. Then if all are ok I would pull all of the plugs, run a compression or leakdown test. If the compression is good, test your plugs and ignition system.
John Hice Owner, Gulf Coast Marine Service, Inc.
Panama City Beach, Fl. 850-258-4423
Photo History of project "Drag"N"Fever" At This Link.
http://forums.screamandfly.com/forum...d.php?t=167460
Ultimate Turbine Warlock, "Johnny Rocket Special"
https://www.screamandfly.com/showthr...arlock-Project
Festivals Of Speed Video.
http://www.youtube.com/watch?v=dVatsUmjUrs
02-04-2009, 10:30 AM #10
First thing I would do is realize its a Cheby motor and learn to live with it!
(If you havent messed with timing seems like a valvetrain issue)"If you ain't hittin bottom.....you ain't jetboatin!"
02-04-2009, 10:56 AM #11
OHhhhh' That just aint right.
02-04-2009, 07:12 PM #12
I will check the compression and do a leak down tommrow. I cleaned the carb and changed the remote filter, and put fresh gas in it, It runs pritty good once it starts.... I dont think the hard starting is the motors fault, I think I just dont know how to start it, I always seem to flood it. It dosent pop any more either and I havent messed with the timing since my timing light went for a drink in the test tank and has not worked right since.
02-04-2009, 07:16 PM #13
Carb, fuel , Bad distributor cap and rotor.....
02-04-2009, 07:21 PM #14
Gas filters
02-04-2009, 08:23 PM #15
check plug wires 5 and 7....... it sounds like its a serious ignition delay and then a firew whil exhaust is open.... ill bet a wire got crossed at the plugs or distributor its definatly sounding like valve train or timing tho.. and holy crap that sounds like chit..
