Results 1 to 14 of 14
Thread: Mirage Setup
11-24-2008, 05:14 PM #1
Mirage Setup
I'm changing from a 20" to a 15" mid. I purchased a 20=15 setback plate from hydrodynamics. I also have 2" bobs spacer plates. Has anyone tried this and should i install the 2" spacers? Any advice/opinion would be great..
11-24-2008, 06:47 PM #2
What model Mirage are you running . On my 3 seater , I went from 6 " set back with a 20" mid , to 10" of setback with the 15" mid .A ski Racer 4 seater may like something differant . But I did it with the jack plate , not spacers . If your using a Factory 15" mid , keep in mind you've already got 2" added in the the clamp bracket . Rich Martin 018
HAVE BATTERIES , WILL TRAVEL !!!
11-24-2008, 07:06 PM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
Rich is correct about the 2" built in set back on the OEM 15" mids. I have raced most every hull designed Brad's ever built ( I was sponcered by Mirage while I was racing ) and that sure seems a long way back on the transom on one of his hulls. IMO The CG would be such that the hull would sure be bow light with that much angle in the fulcrum toward the rear..If your going 10" on jack plate + 2" built in set back AND use spacers I think you be too far back.
Be careful air entrapment hulls with too much bow lift ( set up wrong ) will end up getting ya wet if your not careful....
my .02!Jay @ JSRE
11-24-2008, 07:41 PM #4
Ski Racer
My boat is a 93 Ski Racer (4 seats).. I was running a bobs 6" hydrualic plate. The new plate is a 7" manual setback. So with the extra 2"(15"mid) and the 1" extra from the plate I have a 3" additional setback from before! What I think I'm hearing is that is plenty already..My boat was from Georgia orginally from a guy named "WILLIE BILLUE" anybody remember this boat? I will still be running my R.A. worked 280,I don't know if it will make any more speed but I like the look of the 15" mid with the motor sitting lower. Thanks,Peter.
11-24-2008, 09:19 PM #5
with ski racer and 15" mid i would go with 9" hydrodynamics jack/manual winch type
they are feather light but strong as hell
Brad collins would rig them this way back in 1996-97
My 97 Jaguar river racer even came with one from kaufman,TX (less motor)"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
11-24-2008, 09:52 PM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
Now IMO THATS the ticket !
JayJay @ JSRE
11-24-2008, 11:21 PM #7
Imo..
I contacted HYDRODYNAMICS and the fellow there told me that on his MIRAGE boats the Jackplate he found to work the best was 7" of setback. He made this one for me, it is the cable type manualy ajustable (rachet). I was just wondering if anyone thought the extra 2" spacer plates would be of any benifit.Jay you said it could tend to get a little wet "over". Now I am more confused than before. I should have 9" of setback or 7" ??
11-25-2008, 12:14 AM #85000 RPM
- Sep 2004
- northen CA
- 129
stoker2001
We were going into towerpark last sat saw you going bye. We were on the Genuine Draft. Was that your race motor or river motor?
JJ
11-25-2008, 12:42 AM #9
Must have posted incorrectly. I live in B.C. Canada. And my motor is off my boat swaping mid and setback..
11-25-2008, 12:11 PM #10"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
11-25-2008, 12:15 PM #11
11-25-2008, 01:50 PM #125000 RPM
- Sep 2004
- lago vista texas
- 134
Mirage 20'' to 15''
I have done it all with a 1990 ski racer. I completely restored mine in 2005 and ran a 12'' magnum from Chuck and a stock 260. The boat would get up and air out quick and required that you run a slight amount of negitive trim on the big end. The boat was flighty but fast. I then bought a 15'' offshore 260 and a 9'' jack plate from Chuck with 3'' of drop to run the 15" on a 20'' transom. This allowed a total of 11'' of set back which seemed to be a good combination. I then cut the transom down to allow a normal jack plate with out the drop built in. At this time, I was advised to run a 7'' set back which yieled a total of 9'' setback. My experience is that my current set up is to wet at slower speeds and I'm going to run 1'' spacers an inch at a time to see if I can get it to free up some. When I find the most appealing set back I'll have hydrodynamics build me a new plate. I'm of the opinion that a 9'' in set back with the offshore mid will yield the 11'' in total. I feel like this will be the best combo for me. Good luck , hopefully I can save you from a jack plate collection as vast as mine.
1990 mirage skiracer 2.5 efi
1994 scarab 29, 502 mag.
11-25-2008, 07:17 PM #13Supporting Vendor
- 11,838
- 163
- 11
- 795
Hows it going Gary ? Hows your buddy's motor running I built a while back ?
JayJay @ JSRE
11-26-2008, 11:19 AM #145000 RPM
- Sep 2004
- lago vista texas
- 134
Hauls ASS.
Happy Thanksgiving.
Gary1990 mirage skiracer 2.5 efi
