Results 1 to 7 of 7
    Nov 2008
    Gladstone
    383 Chev, reversion Issue?
    Hi, just like to say this is a great site for info and well discussed forums.
    i have a 383 chev in 19 ft stephens ski boat centre mount soft clucth arrangment. i will list the engine specs below. problem is i have slight evidence of oil in water, not milk shake but still evidence of water. i think the issue could be cam, overlap of inlet & exhaust valves ??
    385 ci
    4.040 bore
    3.75 stroke
    SRP forged flat top pistons 10.8:1
    Crane cam 224/230 @ 0.50" 110 lobe centre (Z-274) grind #
    World product heads Sportsman II's / 64cc chambers / 200cc inlets mild port work
    Elderbrock performer II manifold
    700Dp Holley carb
    engine runs well, nice stong power out of the hull, very strong mid to top end power.
    any advice would be great. cheers
    Oct 2003
    Sanford, Florida
    Steve , Try reposting this in the Jet and V drive area . That where the car motor gurus hange out . Also the Tech section . Good Luck .
    Rich Martin 018
    HAVE BATTERIES , WILL TRAVEL !!!
    Nov 2008
    Gladstone
    Thanks RNM018, i have done that..i didnt realise that i posted it it in this section. cheers
    Little Suamico, Wisconsin
    Did you run a pressure test on the block after it was stoke clearenced? It sounds like a seepage leak internally. For a place to start. With proper adapters engine can be presure tested together.
    Correction stroke clearenced. Did you have the block and heads Magnufluxed before putting it together, yes I check new heads also. Found issues with new components rare but has happened to me.
    CRYSTAL RIVER, FLA
    Also try
    "Where is Lee Harvey Oswald, Now that we really need him?"
    Nov 2003
    Miami, F_L_A
    you have oil in the water or water in the oil??
    BIG difference..
