Results 1 to 12 of 12
Thread: Yamaha
    Jul 2008
    Spain
    Yamaha
    Somebody would give me an opinion about Yamaha 250 3.3l HPDI?
    Oct 2007
    CALI
    what year?????
    Jul 2008
    Spain
    Yamaha
    2007. This motors are no longer avaible. 250 two stroke
    Good motor. If it is new old stock be sure the dealer primes the oil system correctly and take your time on break in.
    Oct 2007
    CALI
    Quote Originally Posted by juanto View Post
    run the serial number and make sure oil pump is updated
    Jul 2008
    Spain
    yamaha
    I ll do it, thanks
    australia
    Z250
    Every 250 2 stroke which I have had experience with(approx 10-15) has blown up at least once if not 2 or three times. All at about 80hrs.
    There has been an oil pump upgrade from Yamaha but this does not appear to have worked.
    If you purchase one good luck
    Jul 2008
    Spain
    Yamaha
    There is no way to avoid it. I just purchased twins
    Quote Originally Posted by Bullshot View Post
    99% of those failures is from the dealer not performing the intial start up procedure allowing the motor to oil itself properly. And after the new owner not following break in properly. They have very tight tolerences and it is critical that everything in the first 20 hours be followed to the letter. I've rigged A LOT of them and put the first 2-3 hours on the motor, very few have come back. Other than that a good motor. Stock up on Ring Free.
    I could not have said it better than capt insane-o
    Sep 2002
    Lakeland,Fla
    DITTO
    Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
    We Put The F. U. in FUN
    94 17MA Maverick 115 Yamaha
    2006 Mustang GT, with a belt driven air cleaner
  12. #12
    Nov 2008
    Follow the break in and proping to the letter, most of the problems i have seen with them are because they are slapped together and sent on thier way. With theese engines good enough is not ever good or enough.
