Results 1 to 5 of 5
Thread: best prop for 07 vegas 300
10-24-2008, 11:43 AM #1Member
- grafton wi
- 50
i have a 07 vegas with a 300xs 3.2 stroker im running at lighting et 28 pitch.prop shaft is even with pad.98 mph gps but rpm hits rev limit at 6500 rpm should i go with a 30 pitch et or different make?if i lower engine to drop rpm speed doesnt increase
10-24-2008, 12:20 PM #2
30p Pro ET four blade or a Peformance Propeller Bullet Cut P4 in 30P.
Both will be easier to drive will get you where you want to go. I've had a Bullet Cut P4 and it's amazing how it holeshots, accelerates and flat out hauls on top end. It's expensive but not much more than the ProET. I think the 3 blade lightning won't lift the whole boat as well as the four blades. Nice rig though. Do you have any pics?
11-13-2008, 08:25 PM #3Member
- grafton wi
- 50
should i have my 28 et worked or buy a used 30p
11-13-2008, 08:36 PM #4TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
11-16-2008, 04:11 AM #55000 RPM
- May 2004
- Washington, Missouri
- 329
Time to step up to a 32 Cleaver. You'll love the loose set you'll get from it.
