Results 16 to 26 of 26
10-31-2008, 05:57 AM #16
Tough to push aluminum through a mig torch, spool gun or tig is the way to go!
Sold the Skater, missing it everyday
12-22-2008, 06:48 AM #17" The Fleet of Old Boats "
12-29-2008, 03:17 AM #18
its doable...
argon gas
turn wire feed speed to 100%
loosten the drive rolls as loos as possible but still able to feed wire
teflon gun liner
mig gun lead needs to be PERFECTALLY straight
set voltage or tap setting on high
4043 wire is your all purpose wire in .035
5356 is your marine grade wire for 5X and 6X alloys and is stiffer and stronger than 4043
argon at set to 30 works good for most general repairs.
i have a millermatic 140 and it works for small porjects and welds like a champ
i also have a thermal dynamics 225 with a spool gun but its got a lot shorter power cord and is used for bigger bench projects,
Ive repaired broken drives with my 140 and 5356.030 wire without a spool gun, but i will say if you hit a spot where it doesnt arc and stops the feed your diggin a rats nest out of the drive rolls..
id only recommend it if you were out of options and had no other choices, ive done so and it worked for me, but its far from Ideal... TIG is the ideal..
they also make a DC stick rod for aluminum and its even worse IMO than forcing a mig gun to feed aluminum
01-05-2009, 11:17 PM #19
Tig is the deal
01-06-2009, 08:39 AM #20
02-17-2009, 10:25 PM #21Member
- Nov 2003
- French Settlement, Louisiana
- 50
You can do it, bu it is worth it for you to purchase a spool gun. These are very easy to weld with.
02-17-2009, 10:36 PM #22
Be careful, if it is a high stress application and you upset the heat treatment in the Aluminum alloy were you are welding you can change its properties. Aluminum alloys are given their strength through precipitation hardening and when you re-heat a treated Al-alloy you run the risk of recrystallizing it an thus undoing a specific heat treatment. Ask yourself if the braces are worth the possibility of making another part weaker, my .02 from a materials stand point.
1970 16ft G.W. Invader~1969 1250 Merc
1971 15ft G.W. INVADER~1974 1500 J Block
11' glen-l TNT
16' Invader under restoration: http://forums.screamandfly.com/forum...hreadid=144970
"Where ever I'm going, heaven or hell I do hope they have an engineering department." ~ Elmer Carl Kiekhafer
02-17-2009, 11:12 PM #23
I was gonna chime in here but 150aint beat me to it. I have a Lincoln Sp130, for aluminum, I had to use some 50 series .035 wire with the steel liner and it did fine. Roller tension was critical. Did alot of work that way, until I made enough to get the TIG. I agree, I'd do again in a pinch, but don't recommend it. REW
02-18-2009, 10:40 AM #24
02-14-2010, 06:27 PM #25Junior Member
- Dec 2007
- canada
a regular mig wire feed will do aluminium....a teflon liner with a short gun is recomended if you dont have drive rollers in the gun handle itself the longer the wire is after the rollers the more chance it has to get balled up in the gun itself you can buy little pads like scotchbrites with a clip to install between the spool of wire and the drive roll assembly...aluminium is dirty chit one of the things that kill liners when welding aluminium one of the biggest problems isnt the fact that it wont be welded but rather the gun liner itself gets gummed up with the oxidation common of aluminium
welding machine with a spool gun is really the way to go
08-28-2011, 07:33 AM #26
I have a lincon 180 HD. Lincoln spool gun ( paid $195) and argon 75%-25% mix. Welds like a dream . Heat stays pretty centralized close to the weld when welding. I would recommend getting a spool gun or like suggested above, get it done with a tig.
Hydro86 Hydrostream Vector
2.4 Bridgeport Offshore Centerhorn EFI
2007 Regal 2860 express cruiser
1996 Rinker 260 Fiesta Vee
Kawasaki 750 ZXI jetski
