Results 31 to 45 of 335
10-14-2008, 03:02 PM #31
Well its good that you found that soft spot before you took it out with the V6. It would be a shame for that thing to get wrecked
"Brandon Field"
Formerly Fieldzy
Silly Rabbit, OMC's are for Kids
1982 Hydrostream Vandal, Currently under Resto
10-23-2008, 09:46 PM #32
Viper recore mmmm yes.
10-25-2008, 07:52 AM #33
Hey Jeff, any progress? Just checking in.
There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
Quinten
86' Hydrostream Vking YT, 2.4 Bridgeport EFI
(Rigging and interior in the works)
88' Hydrostream Voyager, 2.4 200 Merc
Boat of The Month Feb. 2009
resto here, http://forums.screamandfly.com/forum...d.php?t=144414
Dedicated to you Dad, I miss you! 1935-2008
10-25-2008, 11:33 AM #34
Just wondering:
Did you decide to go for the re-core or patch job?
10-26-2008, 04:39 PM #35
Not yet, but i'm getting close. I wanted to make sure the garage was situated before I get down to making a mess. Completely insulated, drywalled, and painted walls and ceiling and 40k BTU ventless installed. Just finished building a 7ft workbench and have a new compressor on the way as we speak. Soooooo.....within the next week I'll get the extra 4 bunks added to the trailer and get after it. Thanks for caring I appreciate the hookup when Midge and I were down there, had a great time with you two....we'll do it again over X-mas when we head back that way. And for those who haven't seen Quinten's Voyager, it turned out great!!! Very very clean!
CC - I'm really thinking I'm just gonna cut it all, get it right, document it, so when and if I ever decide to sell it, the buyer will know what he/she/it is buying. More to come in the not so distant future......
JeffLast edited by Sonik; 10-26-2008 at 04:41 PM. Reason: Can't spell for shti
1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
"The true soldier fights not because he hates what is in front of him, but because he loves what is behind him." -G. K. Chesterton
10-27-2008, 04:53 PM #36There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
Quinten
11-09-2008, 05:08 PM #37
Finally got the opportunity to start some cutting today to see where I'm at. After 20 minutes or so of cutting and grinding, I've got a nice haze going in the garage and the girlfriend decided to share with me that I had stunk up the house with fiberglass and sawdust.....to which my reply was, " Wait till I start laying down new mat and resin!!!" I was left alone for the remainder of my time in the garage..LoL. And this is the result......
^^^^Decided to remove a section of floor behind the seatbox to see what the pad core looked like
^^^^ Piece on the left is the wood floor section from the bilge area up to the seatbox. Note the marks from the stringers which were actually bonded to the floor. The piece on the right is a section of 'glass mat that covered the wood floor which came up in one piece with very little effort.
^^^^ First peek at what was underneath the floor...didn't look bad at first glance....
^^^^ Then I noticed some moisture around the bilge and some more outside the stringers.
^^^^ I couldn't believe this when I pulled the floor up and noticed where the drainback holes were positioned. In the small bulkhead in front of the bilge there was a hole drilled there but it was a good inch or so off the bottom...not so great for letting water out. If you look at the stringers, they are notched on the TOP instead of the bottom which would allow, once again, a good inch of water to develop before it drained out into the bilge well.
^^^^A shot from the stern at the seatbox. As I moved forward I found less and less bad core but there are still a few spots right at the top left and right corners of my cut that have a little soft spot or two...so the seatbox and remainder of the floor come out next.
I'll have some more time to get the seatbox and remainder of the floor out tuesday so stay tuned.1976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
11-09-2008, 06:57 PM #38
11-09-2008, 07:08 PM #39
Its about time!!!!
"Brandon Field"
Formerly Fieldzy
11-09-2008, 08:10 PM #40
you might
want to consider removing those mint coaming pads before they get damaged during the recore...it's tough to get that vinyl pattern done anymore.
JT
11-09-2008, 08:13 PM #411976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
11-09-2008, 08:26 PM #42Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Nice neat Job! Good idea to remove the coaming pads, but it may be difficult. The unplated carriage bolts on my boat had to be sawn off.
I left that bulkhead out altogether, air can easily flow from front to back. Even when I do get water in the boat it dries out really quick.
I also added several extra layers of glass for about 2 feet ahead of the drain, where water would sit. This was on John Speath's advice.
11-09-2008, 08:45 PM #43Screaming And Flying!
- Oct 2003
- Cobourg, ON
- 7,194
Damn, I shouldn't have responded to this post. Now I'm all itchy.
11-09-2008, 08:58 PM #44
11-09-2008, 09:11 PM #451976 Hydrostream Viper - 2.5 EFI
Resto Thread Here
2010 Go-Pro Stuff
