Results 1 to 15 of 32
10-08-2008, 11:09 PM #15000 RPM
- May 2007
- tacoma washington
- 214
marine tech needs some auto tech help
I have my 91 tbi v-8 5spd camaro acting stupid (again) Do we have a auto tech in the house or a savy helper on the related issue
10-09-2008, 06:28 AM #26000 RPM
- Aug 2003
- Mathiston, Ms
- 1,129
i have a 90 iroc with the 350 tpi. not an expert but maybe me or others can help ya with some more details???
Matt
aka boilerdawg
Boatless for the first time in 20 years.
10-09-2008, 06:38 PM #3
I might be able to help you,I know the TBI setup well,its a good system,hardly any problems
10-09-2008, 07:25 PM #4Member
- Aug 2008
- naples
- 63
what is it doing
10-09-2008, 08:28 PM #55000 RPM
- May 2007
- tacoma washington
- 214
engine problem
Have no codes, fuel pressure is 12.5, new injectors, coolant temp sensor, tps, map, sensor, knock sensor doimg it thing, new 02, new module, new pick up coil. start car in morning,searches for a idle, have to feather clutch and gas to get out of driveway, car has a ruff or light studder at 2500 rpms in 2nd gear only. engine will not take load from clutch well at all. when its warm has a light miss. all the time. I put all new mentioned above ac delco parts down to cap, rotor, wires plugs, new fuel filter. compression test great, no leak down problems, pressure tested cooling system to make sure no coolant in any cylinders. Only thing has bein done was a intake replaced 2000 miles ago. but problem started way after that. i have no vacum leaks, i richen up with problem can see o2 changes, create a vacum leak see o2 change. I have a otc genesis scanner and can watch everything but dont see anything. Help please with ideas
10-09-2008, 08:30 PM #65000 RPM
- May 2007
- tacoma washington
- 214
engine problem
Sorry guys, brand new egr and intake was brandnew from dealer
10-09-2008, 08:43 PM #7Member
- Oct 2008
- illinois
- 46
Have the throttle position sensor checked, sometimes they will cause drivability issues that won't show up on a scan, hope this helps.
10-09-2008, 08:53 PM #8
i know this may sound stupid but you mentioned alot of new parts and never once mentioned plug wires......i had one of these give me hell for about 2 months with a mis like you are talking about (mine was and automatic though) and i checked everything until one night i was in a really dark lot late at night and i opened the hood....saw some funky blue light show going on on both sides.....went home and next day changed all the wires and voila....the plug wires run dangerously close to the exhaust manifolds on those cars and can burn a new set in a 15 minute ride.....worth a check.....
1984 28 ghost twin 200 Yamah ProVs (SOLD)
1997 21 Superboat Legend 250 VMAXXX (SOLD)
2001 25 Concept CC 250EFI (SOLD)
2002 24 Superboat Step 250EFI (SOLD)
1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
1994 20 Hydrasport 225 Optimax (SOLD)
1998 27 progression Twin 225 Mercs (SOLD)
2005 23 Kryptonite 300 Promax (SOLD)
10-09-2008, 09:10 PM #95000 RPM
- May 2007
- tacoma washington
- 214
engine problem
sorry forgot plug wires, brand new set have 50 miles on them and they will not burn anything the way they are routed. i swept tps with gragh on my multi meter. Not a glitch
10-09-2008, 09:16 PM #10Member
- Aug 2008
- naples
- 63
is it tuned port w/ long runners or like carb on top of intake. if tuned port check intake air temp senser if messed up acts like choke is on, my dad has 89 corvette w/383 cam heads the works, first three months wouldnt find idle then found that problem and didnt show up on scan. fixed senser and idled perfect well as perfect as cam would let
10-09-2008, 09:17 PM #115000 RPM
- May 2007
- tacoma washington
- 214
engine problem
I got the fix (RAM JET 502) lol and richmond 6spd, now seriously guys please keep ideas coming, because I am just seriously lost and a shamed because I am a ASE master tech also with L1 emission cert. Gm T.B.I is suppose to be easy and simple. I also checked there is tsb for problem through Mitchell or alldata and Gm
10-09-2008, 09:17 PM #125000 RPM
- Jul 2007
- Ms. gulf Coast
- 334
if you have an otc scanner, what is the block learn count on, while you at it what are the o2 sensor cross counts doing [rapidly from high to low to high] or is the o2 counts slow to cross the .050 volt mark.
10-09-2008, 09:19 PM #135000 RPM
- May 2007
- tacoma washington
- 214
engine problem
car is tbi with 5.0 litre and 5spd. air temp sensor showed within 8 degrees cold or warm then was outside with hood idleing in my shop
10-09-2008, 09:22 PM #145000 RPM
- May 2007
- tacoma washington
- 214
engine problem
dont rermeber block count, o2 I would say was alittle lazy switching back and forth
10-09-2008, 09:33 PM #15fuel pressure is 12.5
Also did not notice anything about the IAC...?
Darn almost forgot those factory ECU`s around that year had a bad habit of giving techs all kinds of fits too... Saw many that did basicly what your saying and of course never show up on any scanner...Last edited by Bartman39; 10-09-2008 at 09:37 PM.
