Results 1 to 7 of 7
10-07-2008, 08:21 PM #15000 RPM
- Mass
- 161
Difference between 1 piece and 2 piece heads
What are the differences between 1 piece and 2 piece heads on a v6 merc? Are they interchangeable? Any compression differences or anything? To me the 1 piece heads look better and have one less gasket to worry about. Would somebody ever prefer 2 piece heads?
10-07-2008, 11:34 PM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
The obivious is the differences in the water chamber the two piece being exposed by removing the top gasket plate and the 1 piece a closed water system. Also most 2 piece heads are more like a hemi head and a 1 piece resemble an umbrella , Each can be cut to yield any compression wanted. The 2 piece heads is whats usually refered to as the BAD HEAD BOLT PATTERN motor. The pattern on most 2 piece are from very early V-6 and the bolts are very narrow and are next to the bore itself unlike the newer style 1 piece that are a wider bolt pattern will seal and hold greater compression , the two heads can't be interchanged...
Good luck,
JayJay @ JSRE
10-08-2008, 05:12 AM #35000 RPM
- Mass
- 161
Thanks for the info Jay
10-08-2008, 07:54 AM #4Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
83 up 2.4,s and 2.0s had 2piece heds with the later bolt pattern...Up untill 88...altho tha 2piece heds from 83/88 will bolt on tha later motas, the still don't have the cooling capasity that tha one piece haz, and haz one more gasket to spring a leek....I use the 2 piece all the time without problems, kuz if the cooling system works well, U don't have a problem...But if U cut the 2piece heds for big compression, then U start building chamber heet ya kan't git rid ov...For a river mota, U won't know tha differnce between tha 2 piece and tha lost foam hed....Even tha combustion chamber shape(Hemi/top hat) don't make enuff(if any) differnce to matter...
10-08-2008, 04:47 PM #5
Another thing I have noticed as I'm sure you have Rex, is when you cut the 2 pc. heads you start seeing porosity in the casting due the the process they used to cast the older heads, sometimes you wind up with a big enough pore to cause a "hot spot" that could lead to possible detonation. Dad cut some heads down that you could hardly get a dill pickle slice in the chamber and it look like moon craters in the "squish" area.
-MichaelMichael Chapman
Calhoun Marine
803-897-3806
1166 Midway Rd
Elloree S.Carolina 29047
quartermaster22@gmail.com
http://www.facebook.com/album.php?ai...112543?sk=wall
10-08-2008, 06:09 PM #6Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Hell, datz what bubble gum iz fer, after tha taste iz gone!!!
10-08-2008, 09:12 PM #7
Frickin' Red-nek! Aieee!
