Results 1 to 15 of 19
    Jun 2002
    El Cajon CA.
    Simon Motorsports can repair most 2001 and newer ECU's
    I can repair most 2001 and newer Mercury and Mercruiser ECU's. I can upgrade 2.5 hi performance ECU's also 11350 , and 8494849 .
    1 day turnaround !! Give me a call for more info. 760-440-9334 thanks, Eric
    Feb 2007
    lily lake WI
    can you take my rev limiter out I have a 2001 2.5 280 merc pm me thanks
    Jun 2002
    El Cajon CA.
    yes i can.
    lost in Tennessee
    Great News!!!! Thanks Simon
    North Carolina
    Eric - about how much to bump up the rev limiter on a stock 2004 250 EFI?
    Jun 2002
    El Cajon CA.
    I can move the limiter and lighten the flywheel for 750.00.
    Aug 2005
    Pembroke Pines , Fl
    what would be a safe rpm range for the 300xs.. have you done any testing with them?
    Jun 2002
    El Cajon CA.
    They wake up with a lighter flywheel and the limiter moved to 6800.
    Jun 2002
    El Cajon CA.
    May 2007
    Saginaw,MI
    Just wanted to say thank you to Eric at Simonmotorsports for getting my ECU dialed in on my boat. The best ecu I have run period (Ive run plenty of different one's and none compare).Thanks again Eric for the help and quick turnaround. Joe
    Jun 2002
    El Cajon CA.
    Dec 2006
    Ponchatoula, La.
    Would an upgraded ecu on a 2001 300X make my motor idle any better? Any better performance other than the rev limiter? Thanks!
  13. #13
    ILL
    WOW This is great news!!!
    Thank you Skydog
    06 Daytona 27'
    600 Cubic
    Whipple 8.3
  14. #14
    Jun 2001
    DISCOVERY BAY
    ecu
    just in time warrantee is over !!!! this is great 300xs
    FINAL TOUCH DETAILING
  15. #15
    Jul 2002
    Las Vegas, NV
    Hey Eric, local guy has a 280 that threw a MAP sensor code - can you fix that?
    Keith-
