Results 1 to 11 of 11
Thread: DDT info
09-26-2008, 08:42 AM #15000 RPM
- TN
- 470
- 7
DDT info
when testing A49 with DDT tester, how do you know if the box is good? in the manual, it just talks about checking MAP sensors, air temp, etc. How do you know if the box is good?
09-26-2008, 08:57 AM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
I find most of the time when I find a BAD box the DDT ( OTC 4000 ) will signal "No SIGNAL FROM ECU "
hope that helps,
JayJay @ JSRE
09-26-2008, 09:21 AM #35000 RPM
- TN
- 470
- 7
Jay, i hate to keep bugging you, but if my box performs perfectly except for warm startups, what would i look for on the DDT? Thanks
09-26-2008, 09:32 AM #4Supporting Vendor
- 11,838
- 163
- 11
- 795
Not bugging me at all, we all ( including ME ) learn from all the great information and sharing from prior experiances...
1st are the injectors clean lately ? ( By Brucato )
2nd do you have a fuel pressure gauge attached ?
3rd when you cut pump off does the pressure drop to zero quickly ?
4th do you feel your"issue" a rich or lean condition ?
5th is your battery HOT and not running at 12.5 or more volts
6th at 1500 rpms is your voltage 14 vbolts or MORE ?
Give me a call at my cell 1 281 798 3150 cst I'd be glad to maybe "cuss and discuss" your issue..I'm here now ! 9:30 am CST
JayJay @ JSRE
09-26-2008, 09:46 AM #55000 RPM
- TN
- 470
- 7
1. yes by brucato
2. yes, holds 40lbs. consistently. i've tried 2 regulators.
3. it drops quickly to 5lbs., then slowly to zero.
4. rich, smokes immensely when it finally starts.
5. yes, i've tried it from 11.8 up to 13 volts.
6. i haven't checked that. it starts perfect at any voltage until i let it run for 10 minutes. how would this affect startup? does the box know if the voltage regulator is bad?
09-26-2008, 10:04 AM #6Supporting Vendor
- 11,838
- 163
- 11
- 795
If the voltage is spiking up and down it will have an adverse effect on the ECU as in a perfect world it ( the ECU ) "needs" consistant voltage..
JayJay @ JSRE
09-26-2008, 10:21 AM #75000 RPM
- TN
- 470
- 7
i don't have a scope but i have checked with a voltmeter which wouldn't show spikes. maybe the regulator is breaking down when it warms up?
09-26-2008, 10:29 AM #86000 RPM
- Jul 2003
- Muskoka, Ontario
- 1,061
Do you have your enrichment wire from the ecu hooked to the starter relay??
09-26-2008, 10:35 AM #95000 RPM
- TN
- 470
- 7
no, the enrichment wire is disconnected and taped.
09-29-2008, 07:00 AM #106000 RPM
- Loudon Tn
- 1,430
- 7
- 59
problem
check air sensor ohms
09-29-2008, 07:39 AM #115000 RPM
- TN
- 470
- 7
i've tried 2 and 1 was new. #1=6500 ohms, #2=7500 ohms
