Results 1 to 15 of 29
Thread: Looking for Speed Coat
09-24-2008, 11:28 AM #15000 RPM
- Aug 2008
- Greensboro North Carolina
- 124
Back when I was drag racing we did our bottoms with this tuff called speed coat. It was supposed to be good for a couple mph but most of all it was good after you would work on bottom to coat and blend. If anybody knows where I can find some please help. Todd
09-24-2008, 11:29 AM #2
I believe you'll find equal or better results with primer sanded with 320 to 400.
09-24-2008, 11:46 AM #3
09-24-2008, 11:49 AM #4
If you really want the stuff the blow boat racers use it.
.......................................................................LETS STORM THE CASTLE BOYS!
09-24-2008, 12:30 PM #5
This is what blowboaters are using
http://www.mclubemarine.com/hullkote/ It's slightly different from the typical polish w/teflon
RainX is another that gets used..
09-24-2008, 01:30 PM #6
I agree with Racemand and Wile!
The results of "Go-Fast" applications seem to be somewhat inconsistent as far as improving performance. Many of these do nothing more than remove the wax from surface (getting the wax off is good).
If it's top speed you're looking for, polishing or waxing the surfaces can make it slightly worse. The "slick" surface will maintain a "laminar" water flow for a little longer on the lifting surface, which generates slightly more drag than a separated, turbulent flow. This is the "stickiness" that can be experienced when running on very smooth water or with "polished" or waxed running surfaces of your boat bottoms.
Best results seem to be achieved by wet-sanding with fine emery cloth (use 400 grit). This will take out all the scratches, but won't create the "stickyness" or "sheen" that causes the additional drag.
Here is a good thread on subject of surface finishLast edited by Jimboat; 09-24-2008 at 04:05 PM.
WavetoWave liked this post
09-24-2008, 02:45 PM #77000 RPM
- Central Florida
- 2,643
- 37
- 32
- 219
Try Lubri-Bond A. Made by Everlube. One of the west coast marine catalog places used to stock it.
09-24-2008, 04:07 PM #85000 RPM
- Aug 2008
- 124
Thanks for the Info
I primed the area today and gonna start snding tomorow.400 grit Thanks
09-24-2008, 08:10 PM #96000 RPM
- Jan 2005
- South Florida
- 1,360
Its called LubriBond-A Speedcoat. Available in aerosol spray or brush-on, from Rex Marine in California. www.RexMar.com Hope this helps.
09-24-2008, 09:05 PM #105000 RPM
- Aug 2008
- 124
This is it
Thanks airide we all used this stuff back in the day Raceguy what do you think? I acually just finished using primer and 400 grit. But I would like to know if all those years of drag racing I was using somthing that realy was no helping. Thanks
09-25-2008, 04:57 AM #11
sweetcoat
heard RM AND T2x had some kind of secret honey coating but must be hush hush they didnt bring it up on this tread so im not gonna either.
MITCH HARDEE 803-974-0350 --- 95 CUSTOM BASS RR STV/300drag-- 2004 STV RR/300drag---14ft fastcraft/12in/ssm--F.I. 3cyl -whittled from 300-drag --2008 FTPB STV RR( POC FACTORY BUYBACK) IRATATE A LIBERail --missspell som'um--SPONSORS --THOROUGHBREDS INC.
09-25-2008, 05:07 AM #12
KIRCHNER liked this post
09-25-2008, 06:37 AM #13
So much for speed SECRETS
09-25-2008, 06:54 AM #145000 RPM
- Aug 2007
- Eastern NOrth Carolina
- 268
I'm not an experienced expert on this particular application, but my niave perspective would say that the combination of wetsanding followed by superhydrophobic / low surface energy coating (silicone-based like rainex or some of the newest siloxane-based two part polyurethane coatings) should give the greatest degree of turbulentd flow and minimum drag.
09-25-2008, 06:59 AM #157000 RPM
- Apr 2008
- Washington N.C.
- 2,154
Rex marine, they carried the stuff, don't no if they still do.
