Results 1 to 15 of 18
Thread: Ohh Well there goes an axle
09-16-2008, 04:03 PM #1
I was all ready to go out Sunday. Topped off my oil tanks, changed my gear oil, then I noticed one of the wheels on the trailer was a bit tilted. I moved the trailer up in the yard but the wheel still looked off. I checked the lugs hoping they were loose, they weren't.
Jacked her up and pulled the wheel and sure enough there was a crack at the end of the axle right by the spindle.
Luckily I caught it before I went out, this could have been ugly.
Anyway now I have a decision to make. I currently have a leaf spring setup with tandem axles. The manufacturer told me I can convert the trailer over to a torsion setup. He said it will last longer and the trailer will ride better. It's basically like having independent suspension.
The downside is the $$$$. To do it I would have to replace both axles and transfer the brakes over to the new axle.David
______________________
2000 Powerplay Sportdeck
09-16-2008, 04:07 PM #2
I just did it on my Pantera trailer this past winter. Went from leaf to torsion, 3500 lbs each axle, moved the brakes (drums) and upgraded all of the hardware to stainless. I also had a few other things done too. I was into it for around $1500.
2006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
09-16-2008, 04:14 PM #3
Do it !!!!!!!!!! if the brakes and backing plates are good on your axle it's VERY good odds that you can flop them onto your new axles with min. BS and not even having to unhook them.....it will tow smoother ride better and if you ever have a wheel / bearing / axle or flat you can just pull the wheel off and get to some place to fix it...even a 100 mile shot is nothing if you can just be smart about it and take the bad wheel off and run on 3
09-16-2008, 04:15 PM #4Went from leaf to torsion
I'm breaking the bank this season. This spring I overhauled the trailer, new stainless steel disc break setup with new stainless brake lines, new master cylinder, wheel bearings etc.
Plus rerigged to a pair of 2005 motors.
Now I'm looking at about $1,100 to do these axles. I'm most likely going to do it (torsion setup) because sooner or later the other axle is going to go anyway.
Salt water is a killer. No matter how much you wash and flush.David
09-16-2008, 04:20 PM #5if the brakes and backing plates are good on your axle it's VERY good odds that you can flop them onto your new axles with min. BS and not even having to unhook them
He said they do the conversion (from leaf to torsion) all the time for their customers.David
09-16-2008, 04:21 PM #62006 Spectre 24' SCS
2001 Allison XB2003
2006 Mercury 250XS
Go Daddy Go! Racing
09-16-2008, 04:22 PM #72006 Spectre 24' SCS
2001 Allison XB2003
2006 Mercury 250XS
Go Daddy Go! Racing
09-16-2008, 04:25 PM #8
New axles
These new axles sure look purdy.
http://www.floridatrailersinc.com/pr...sh-7000-2b.htmDavid
09-16-2008, 04:29 PM #9Did he give you a price on just replacing both asles with leaf spring setups? I can't imagine it's more than a few hundred less than the torsions??? Maybe $300-400 difference?<!-- / message --><!-- sig -->David
09-16-2008, 04:30 PM #102006 Spectre 24' SCS
2001 Allison XB2003
2006 Mercury 250XS
Go Daddy Go! Racing
09-16-2008, 04:34 PM #11Mine is a South Florida Trailer, and it's original to my 95' Pantera.<!-- / message --><!-- sig -->
My South Florida trailer came originally with the Powerplay.
They make a nice trailer and Alex (the owner) is extremely helpful.David
09-16-2008, 04:36 PM #12
Ziemer,
Did you change the axles yourself or did South Florida do it?David
09-16-2008, 04:40 PM #13
Some of those axles have removable spindles and you can get a spare tire holder that incorporates a spare spindle and hub kit as well. Swapping out a spindle is pretty easy if you ever have to.
09-17-2008, 11:26 AM #142006 Spectre 24' SCS
2001 Allison XB2003
2006 Mercury 250XS
Go Daddy Go! Racing
09-17-2008, 11:55 AM #15
Get it done, then you can make the run to Conn. for the river run!!!!!! Chuck
CHUCK & TRACY FREELAND
1990 25 Talon with twin Merc. 300XS's
1983 Mako 21 with Merc. 225.
www.Fullthrottlepowerboats.com
NEVER FORGET 9/11
Give a man a fish, and he eats for a day. Give a man a welfare check, a free cellphone, food stamps, section 8 housing, a six-pack of beer and he'll vote for a Democrat the rest of his life.
