Results 1 to 7 of 7
09-05-2008, 11:51 AM #15000 RPM
- May 2008
- new york
- 104
**NEED HIGHER RPMs & HIGHER SPEED
I have a 1987 21' Velocity that I just put a Mercury 99' 225 Pro Max with a 24P Trophy Prop and the RPMs are only 5500 and speed is 60MPH. I set the motor shaft 1" below the pad. I was wondering if I should lower the motor or raise it. I do not think I am getting up on the pad. Any help would be appreciated John
09-05-2008, 05:21 PM #2
if your running a 24 or 25 pitch i'd say you motor is at the right hight. what ie your compression? where is your timeing set?
09-05-2008, 07:13 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
my 2 cents
You need to check spark gas and comp..... something is wrong. 21 foot ck mate 24 choppper 7000 rpm.
09-06-2008, 06:55 AM #4
Well he is running a trophy prop which is completely differant from a chopper prop. what does the boat weigh? you might want to try a 21 trophy because that motor does not really start making power till ya get to 6,000 rpms. So in your case a lower pitch 4 blade or the same pitch in a 3 blade will help you get the rpms up and your speed up to. This is because you need to get in the motors power band.
09-06-2008, 06:56 AM #5
ALSO how much setback are you running?
09-06-2008, 10:07 AM #65000 RPM
- May 2008
- new york
- 104
Jimmy, I have a 6" setback; Any info would help
09-06-2008, 10:10 AM #75000 RPM
- May 2008
- new york
- 104
Also, the motor is a 99' but only had about 40 hours on it. It was like it just came right out of the box.
