Results 1 to 6 of 6
Thread: 502 water problems
08-27-2008, 07:42 PM #1New Member
- Aug 2008
- muskoka ont
502 water problems
ok the motor was over heated, hose blew off operator never noticed heat till it was to late
heads where warped had them sent away fixed reinstalled still getting water in #6 &7 cyl checked the block for warps seems check ok no visable cracks in cyl no water seems to enter oil checked the exhaust stumped ??
08-27-2008, 08:54 PM #2
Did you replace the riser gaskets? Did you pressure test the block?
08-28-2008, 08:09 AM #3
Very Common
You are not alone, in the last 4 months friends with the same motors have had the same problems.
The exhaust minfolds/headers seem to be the problem. The water jacketed stainless headers all crack after so many seasons. And the manifolds can leak or suck water back in the cyclinders if you don't have a realy downward bend. The rear cylinders seem to be the ones most affected.
I don't know if this an option for you, but one fix that I am aware of is to dry out the exhaust. In other words run water diverters out the sides of the boat. It's something to look into. My friend Dean is running 540's in a 35 cigarette mistress, his started having the same problems as you. He will be going to a dry exhasust this winter.
Lastly, you said the heads were done. Was the block checked for warp???. Sometimes you have to deck the block before you slap the heads back on. You have to use a straight edge across the cyclinders and break out the feeler guage set. The manual should say how many thousandths of an inch is acceptable.
HVBoats love hundred dollar bills.
08-31-2008, 02:19 PM #4New Member
- Aug 2008
- muskoka ont
ya checked the block with straight edge &feeler gauge & seems ok haveing manifolds check now
09-01-2008, 06:05 PM #55000 RPM
- May 2007
- Wright City, MO USA(Transplanted Seattlite)
- 396
How much was taken off the heads?
Was the intake also milled/refitted?
6? and 7, not 7 & 8 ?
Look/see the last intake gaskets VERY carefully.
09-01-2008, 07:25 PM #6
My 496 leaks into #7 on shut down I open the manifold drains and before I run her I pull #7 plug turn her over till clear then fire her up. She's fine while running. Its the manifolds their warped a tad between the base and riser. When the seasons over and the motor goes for its fall rebuild their getting faced too and some custom graphite steel core gaskets made.
.......................................................................LETS STORM THE CASTLE BOYS!
