Results 1 to 14 of 14
Thread: Transom Knees
    Jul 2002
    Calais, ME
    Transom Knees
    Has anyone out there added any transom knees to a HYDROSTREAM Vector? Is it worth the extra effort? I'm in the process of redoing the floor and wonder if I should add some knees to it.
    ------------'82 Vector - Mercury 2.4 Bridgeport "MOD"
    "Life is short - Get there fast...MERCURY"
    Mobile Al.
    Hey vector mike
    I think it's always best to add knees, will make the hull alot
    stronger..And you'll get less flex..
    T-Rex was doing a build-up that showed some really nice knees.
    Plus over at H/S has a really good project..
    T-Rex
    HydroStream
    Later Larry
    Like This
    G-Man, Sunshine Syndicate |
    Jul 2002
    Calais, ME
    knees
    I have seen some on an ACTION before that were all drilled with holes to lighten them up. Do you think this would take away from the strength?
    Mobile Al.
    Lighting Holes would be good.. Just be careful with them,
    This picture is from By-U-Boyz River Racers..
    Check out the T-Rex LINK.. You will learn ALOT..
    Later Larry
    Jul 2002
    Calais, ME
    Question
    I didn't see the T-REX link. Do they have a web address? What size holes would be good for lightening?
    Jul 2002
    Calais, ME
    T-REX
    I just found T-REX under the BY-U-BOYZ link. Thanks for the info!
    Home
    2 things to consider about those holes-
    1st the wood is pretty light so your not saving a "hole" lot in wieght.
    2nd the hole makes it a bit harder to cover with glass. The flat panel is just covered but the hole should be sealed. If you drill through the covered panel it would be easier, but if laminated with the hole...
    It does make it look better though.
    '90 STV
    '96 260
    under construction
    for far too long
    Jul 2002
    Calais, ME
    knees
    I guess I will be putting some in.
    THANKS AGAIN!
    Jan 1970
    Post(s)
    Thread(s)
    just some advice make sure when you make your knees you cut them to fit flush with the floor the deck and the transom then tie them in on both sides with glass!
    Jul 2002
    Calais, ME
    KNEES
    What size wood would you use? 1/2"?
  12. #12
    Jan 1970
    Post(s)
    Thread(s)
    yeah 1/2 is fine!! thats what i used on my action!!
  13. #13
    Jul 2002
    Calais, ME
    Question
    What type of matting did you use? Chopped or weave? If weave what size?
  14. #14
    Jan 1970
    Post(s)
    Thread(s)
    i used a biaxle wooven with a matt backing in english just in case your not fimilar with that all it is a single piece of fiberglass with bidirectional strands with a regular matt backing
