Results 1 to 15 of 51
08-18-2008, 09:29 AM #1
27SRX vs. 29SRX.....different rake?
I run a DAH 27 SRX on my Vegas, but I tried a stock 29 SRX a while ago. The thing didn't have any lift at all, and didn't run any faster than the 27. My prop guy said that they 29 SRX's have desisgned for lighter boat like tunnels....they use the airpressure for most of their lift....not the prop.
Has anyone measured out one of the 29 SRX's? Do they have a different blade profile and rake than the 27's?
ThanksIan
...boatless for now.
08-18-2008, 09:39 AM #2
if you have a worked dah prop.. it won't run just like a stock 27....
i have also had 3 of the same props!!!!!!!!!!!!!!!!!!! all ran a little different.....
that is why you see these race guys with several of the drag props in the same pitch...
one might be quicker out of the hole, and the other better top end!!!!!!
i have also seen worked props be way off on pitch too!!!!!!! i have a 22 that runs like a 24... and a 23 that runs like a 20....
you can't compare a worked prop to a stock out of the box prop!!!
JMO
roy
roy93 xr 2001 drag with a 15" drag
92 xb 2002 comp with a 15" drag
R.I.P. Phil "rpm racing" Watch over the rest of us my friend.
ssv1761982 liked this post
08-18-2008, 07:55 PM #3Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
08-18-2008, 07:59 PM #4
Kinda funny this popped up. I have a 27 and 29 SRX both by DAH. I have been running the 27 all summer, but recently tried the 29. No faster and it kept blowing out because I trimmed too high to get the bow to come up. Something must be different.
08-18-2008, 08:19 PM #5
I have both 27 and 29 and both were worked by DAH ,the 29 was worked for my boat motor combo and was a easy 8 mph faster than the 27 and would nearly pull the studs out of the seats it pulled so hard and not to mention would run the bow at any angle you trimmed it to. Might give them a call and have them set it up for your package
20 SHADOW 300+ V8
08-19-2008, 01:35 PM #6
DAH O NO!!!!!!!!!!!!!!!!!!!!!
Skydog2011 DCB F26
2017 300 XS DBR
08-19-2008, 01:39 PM #7Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
God, Country, and Fast Boats
08-19-2008, 01:44 PM #8
Just get the shiny package Bigbore loves it!! Gained 12MPH!!!!
Skydog2011 DCB F26
2017 300 XS DBR
08-19-2008, 02:09 PM #9Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
08-19-2008, 02:11 PM #10
ha ha ha!!
2011 DCB F26
2017 300 XS DBR
08-19-2008, 11:00 PM #11
08-20-2008, 09:23 AM #12
08-20-2008, 10:51 AM #13
08-20-2008, 08:06 PM #14
So who can i send my 29 SRX to have a hub put in (omc) the actual stainless hub of the prop has been cut down flush with the blades (front of the hub) I think it may need some sort of custom hub of thrust washer i have never seen this before. My local prop shop cant even put the hub in straight with out ****ing it up so i have had to burn out two brand new hubs already ill try to post pics tomarrow.
08-20-2008, 08:17 PM #15
I gotta try that "shiny package" thing.That would get me like 120mph.That must be Area 51 Top Secret because Balzy never filled me in on that trick
