Results 1 to 7 of 7
08-15-2008, 12:43 PM #1
What's the difference between Merc 1" 15 Spline and Omc 1" 15 Spline Prop shaft?
I know the splines on the OMC are shorter than the Merc but...
Is it overall length?
Is it the Thread size on the end?
Is it the taper?
Thanks,
Ken
08-15-2008, 12:52 PM #2
A Merc prop will only go about 1/2 way on an OMC
You can slide an OMC prop on the Merc. I don't know what else may be different.
08-15-2008, 01:26 PM #3
Nothing really. The OMC splines are about 1" or shorter than the Merc ones. If you take a Merc prop and go to put it on an OMC propshaft, you have to drill away some of the splines, or rehub it.
Keith-
08-15-2008, 02:17 PM #4
So a prop with an OMC hub should be considered universal between Merc and OMC?
08-15-2008, 02:22 PM #5
Yup. Small shaft Merc, that is.
08-15-2008, 02:25 PM #6
when running the omc on a merc you will need a shorter lock nut I think.
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
08-15-2008, 06:47 PM #7
Thanks for the info!
Ken
