Results 1 to 8 of 8
Thread: 300x Powerhead
    appleton,Wi
    300x Powerhead
    Well,
    I never would have guessed it but 5 days after melting #6,Mercury has warranteed the piston as a failure and replaced my powerhead with a reman.,and i'm ready for the water.WOW!!!!It's not supposed to happen this way,finally something goes my way.
    Chris
    Boatless but want a Progression, Super, Tuff, Activator, Scorpion, ish !!!
    Oct 2003
    Sanford, Florida
    Is the new power head dressed with the old electronis? If I recall you had the original problem on #6 also . Rich Martin 018
    appleton,Wi
    Yes,with old electronics
    The first meltdown was due to old gas,and this time was due to piston failure(locating pin come loose)
    good to hear,better luck this time
    Jul 2004
    fenton, michigan
    double check your electronics....I just rebuilt mine and in 10 minutes of run time burned dwon the same two cylinders again. I thought the first blow up was due to bad gas, now I am thinking it was a fuel deliver problem....
    Pretty sure I won't be getting any warranty out of my 7 year old motor.
    appleton,Wi
    My 2nd explosion was
    Piston defect.Just shredded the sleeve,piston block. Ran the reman. 3hrs yesterday flawlessly,pulled the plugs,checked everything over,looked good,so i put in new plugs for my next run.
    chris
    Vernon CT
    Good to here..Maybe you got a winner this time! Al
    Georgia
    7 Thread(s)
    I've been dyin' to ask this, but figured somebody else would beat me to it. If I understand all this right, here's what I can't figure out: You said the powerhead first blew from bad gas, and also someone rebuilt it as a home job. So how did you get Merc to warranty a powerhead that had a previous non-warranty failure, when it was rebuilt outside of Merc authorized service in somebody's home shop? I would have figured that once somebody else touched it that the warranty was kaput.
