Results 1 to 2 of 2
Thread: left lower unit question???
07-26-2008, 06:59 PM #1Junior Member
- Dec 2007
- kincardine
- 16
will a left rotation lower unit work on a right handed motor for a 1993 2.5L mercury 200? i found a 1999 lower unit with a left handed rotation will this work and what do i have to do to make it work if it will>? also will this lower bolt up to my older engine>?? and what rotatio prop will it need if it will work on my engine>>>>?
thanks
07-26-2008, 07:19 PM #2
my understanding is that you can run it right handed...But...........
You CAN NOT run a right hand left
I know that the front bearing and prop shaft is the big differnce.........
yes it will bolt up and depending on which way you run it will depend on what prop...
I could be all wrong so I want to listen in to this to
