Results 1 to 11 of 11
06-18-2008, 08:52 PM #1
Prop help? - 1988 Hydrostream Voodoo
Hey guys i have a 1987 hydrstream voodoo (260 lbs) with a 1988 50hp longshaft mariner.
Currently running a (10 3/8"dia x 18" pitch) cupped stainless chopper, takes a while to plane.
Looking for something with a bit better hole shot.
Any prop suggestions? Pitch?
Thanks.
<!-- / message --><!-- edit note -->
<!-- / message --><!-- controls -->Last edited by sl0an3r; 07-22-2008 at 03:08 PM.
06-18-2008, 09:03 PM #25000 RPM
- Nov 2003
- Canada
- 572
18" small diameter through hub Mercury cleaver. The bigger diameter ones won't let it turn enough RPM. The 18" chopper is a great top ender but hard to plane.
06-18-2008, 09:44 PM #3
i was thinking a cleaver, you wouldnt happen to know how much they go for would ya?
06-18-2008, 09:52 PM #45000 RPM
- Nov 2003
- Canada
- 572
Lots of $$$
Part # 48-891506A03 (11"dia x 18" pitch) Retails for about $780 USD. Another thing that seems to help the holeshot, is getting weight of of the ass end of the boat. I run a garden tractor battery as opposed to a regular full sized marine battery. I also see you have the motor on the transom. I had HydroDynamics make me a 3-1/2" setback, with zero lift built into it in the lowest position which effectively lowered the motor and worked well.Last edited by XSive; 06-18-2008 at 09:56 PM.
06-18-2008, 11:18 PM #5
Does it have power Trim?
"Brandon Field"
Formerly Fieldzy
Silly Rabbit, OMC's are for Kids
1982 Hydrostream Vandal, Currently under Resto
06-19-2008, 10:15 AM #6
06-19-2008, 10:18 AM #7
06-19-2008, 07:35 PM #8Team Member
- Lake Coochiching, Ontario
- 7,755
- 272
- 485
- 1577
- 6 Post(s)
A cleaver will be worse for planing than your chopper.
I tried a cleaver when I had my Voo Doo and it was barely possible to get on a plane.
06-19-2008, 08:43 PM #95000 RPM
- Nov 2003
- Canada
- 572
06-22-2008, 08:43 PM #10Team Member
- 7,755
- 272
- 485
- 1577
- 6 Post(s)
I had a small 25 HP cleaver that was re-hubbed for the 60 HP Mercs. It was a DAH modified beauty.
The prop hub that was a lot smaller than the motor hub. A combination of thru hub and over hub. It would barely plane. It wasn't near as fast as my round ears either.
06-25-2008, 07:16 PM #11
I have an 18" Merc thru-hub cleaver
It's about an hour away but I'll try to get a photo this weekend.
Does 400 plus shipping interest you?
LMK,
Thanks
