Results 1 to 15 of 55
Thread: What does this line do?
05-28-2008, 01:04 AM #1
oil injection removal pictures
I found this looks to be vacuum line off circled in red. What is its function? My motor stops pulling at 6100 its a 225PM with 7500 limiter. This is not my motor Simmons I think just for illustration. Could this be the culprit?
Last edited by whipper; 07-20-2008 at 08:37 PM. Reason: better to find under oil injection
05-28-2008, 01:34 AM #2
Its a pressure regulator. The line off the top does what?
05-28-2008, 05:12 AM #3
being fuel injected i'd say it is for the fuel pressure regulator.as you gas it up it'l suck more thus upping the fuel pressure
05-28-2008, 06:15 AM #4
I thought that fuel pressure remains constant.
On my motor, that fitting on the regulator tees into the TPI vac hose. When I installed my PCU (doesn't use a TPI), I clipped out the tee and just hooked the regulator barb directly to the hose barb on the intake manifold.Last edited by pyro; 06-21-2008 at 06:29 AM.
05-28-2008, 06:26 AM #5
i cant see the pic but i agree with pyro. thats how mine is set up. the ecu fuel map gets sucked on by the little hose the pulles differant amounts of vaccum called load at differant rpms which sends the amount of fuel by the injector according to a certain percent which has been programed for that load and rpm. if the hose is unplugged it will run full rich
DSRA / ODBA
JETTON MOTOR SPORTS
2008 DSRA Prostock High Points Champ
2007, 2008 ODBA Prostock World Champion
2014 ODBA Modified World Champion
Triad DR-20
05-28-2008, 06:45 AM #6
Ah OK, maybe that's what the Aussie fellow was trying to say. Manifold vacuum DOES control fuel delivery in this sense by measn of the MAP or TPI sensor, but not by means of the vent hookup on top of the regulator.
05-28-2008, 10:32 AM #7
OK, rich idle and rich mid range how does it affect fuel dilivery at wot? Would I still get full fuel delivery? The reason I ask is at WOT im only getting 6100. Im pretty sure its a timming issue because I set the timming myself and now I think I didnt do it right. This line off would explain a flooding feel after idleing and shut down. Was hard to restart. At wot though she stops pulling at 6100 and starts to lurch.My feeling is im retarted on the timming thus not getting full power. im going to see a guy today about getting my timming checked and pick up a new line.
05-28-2008, 11:46 AM #85000 RPM
- Jul 2005
- Beaumont, Texas
- 779
The line hooked to the top of the regulator is a vaccum reference port. Under idle and steady cruise conditions , when the engine is pulling it's greatest vacuum, it will drop the fuel pressure by about 5-7psi. When the engine is under it's heaviest load the vacuum will be the lowest thus the pressure will go to the default setting of 39-42psi. IF you disconnect the line to the regulator it will fatten up the engine slightly in the high vacuum/low load areas...
Rick2006 Gambler 2200DC/2006 250XS
NICE PAIR liked this post
05-28-2008, 12:27 PM #9
Wow, that's news to me. Interesting.
I always thought that pressure was kept constant, and the ECU's fuel curve and resulting injector duration was used to precisely control fuel delivery. hmmph. We learn something new every day...'89 Hydrostream Vegas XT, '90 Merc 2.4 Bridgeport PCU EFI
05-28-2008, 05:48 PM #10
I see this motor in the picture has no bleed lines whats up with that what does that do and also can it be done to a 250efi.
1988 reaction19-sold
1978 action20 w/ 250 efi-sold
2003 quartershot T4-sold
1978 16 action with 15'' 2.4 -sold
1979 mako21 w/ evinrude 150 faststrike-sold
1995 18 ACTION COPY w/ CCMS HO2FO!-sold
1981 24' manta w/ a v8
05-29-2008, 10:15 AM #11
anybody!!!!!
05-29-2008, 10:38 AM #12Markus' Performance Boating Links:
05-29-2008, 11:53 AM #13
Ahhh... I eat crow then. I was wrong. Sorry for doubting fact, and thanks for filling me in.
05-29-2008, 12:42 PM #14
06-21-2008, 03:03 AM #15
Thanks guys everything is Good now! Just gota set up my timming again. I got Jays TDC guadge and the 0 mark on the ProMax was off by two deg. Im running 22 or 23 i figure right now. No harm retarted but its killing my top end a bit. Ill set her up to 25 at 3000 rpm and see how she likes that. In the manual for the 96 225ProMax the timming is a little unclear? One page says 23 deg and the other 25 at 3000rpm? What would the differance be in timming if set to 25 at 3000rpm and the crank speed timming after set at 3000? Would the crank speed timming be higher or lower than 25 or the same? Should I just set at 25 turning it over?
