Results 1 to 8 of 8
Thread: OMC 225 HP flywheel
05-08-2008, 02:55 PM #1Member
- Oct 2006
- 58
OMC 225 HP flywheel
HI, I have a little problem.
On my racing engine, I use light flywheel, but today, the magnet for timing(not charging), is dead!!!
Have you a solution to change it.It seem it is the same like std flywheel...
thanks by advance
my boat....
<!-- / message --><!-- attachments -->
05-09-2008, 01:50 AM #2
Is this the Gold flywheel? If so call or p.m. Al Stoker. He's a Supporting Vender on this site & can probably help you.
Is that a real Champ motor? I can see that the mid is a 12'' but how about the powerhead? Cool boat!Last edited by RUDERIOT; 05-09-2008 at 01:53 AM.
I hate to loose more than I love to win.
Keep your damn America hatin' Nobama votin' COMMIE HANDS off my guns
05-09-2008, 02:21 AM #3Member
- Oct 2006
- 58
many thanks it si a flywhell black and anodized gold.
can you give me the email to al stoker.
I have less difficulties to write than to speak..I am french.....
it is a 6" midllesection, with a tuned 5 ports 3l OMC with carbs..
185/190km/h......and a sound...a music....
if you give me you email, i send you a 24 heures de rouen vidéo, with my oMC...
regards
jm
05-09-2008, 02:45 AM #4
jm your english is very good!
I can't find his email & I understand he don't like to get them anyway. If you ask for his email on scream & fly I'm sure someone has it & will tell you.
If no one has given it to you by noon tomorrow & call him for you and try to get it or at least see if he has what you need. I'll then let you know what he told me.
This will save your phone bill$$$$I hate to loose more than I love to win.
05-09-2008, 11:11 AM #57000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Alan is "racer" here on the board. Try sending a private message.
What you have to do is remove the magnet and replace with one salvaged from a production flywheel. I believe the resin is just epoxy. Mild heat should soften. But don't get it too hot or the magnetism goes away. So practice technique on the bad magnet on your race wheel.
There are epoxy solvents if you have access to industrial chemicals. Paint remover containing methylene chloride will probably work. Slowly.
05-09-2008, 11:24 AM #67000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
Also - If you disassemble the race flywheel, be certain to mark the pieces so you can reassemble in exactly the same configuration. Use paint or indelible marking pen, no scratch or punch marks. Be careful with the bolts in the outer ring, some may be different lenghts to achieve proper balance. So keep track of which bolt came from each hole until you verify they are equal.
05-09-2008, 11:45 PM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
It would be rare for the magnet on the sensor to go bad, how did you check it? I might have one but will not be able to check until next tuesday.
05-11-2008, 10:25 AM #8Member
- Oct 2006
- 58
Hi,racer..
I check it , when I put little metal spare, like a washer, it is not attract by the magnet...so not information to the trigger when the flywheel turn....
what do you thinks about that?
best regards
jm
