Results 1 to 4 of 4
Thread: watre spots
05-05-2008, 08:36 AM #1
watre spots
what is a good product to remove hard water spots from a mid section? has recently been epoxy painted & dont want to scratch or dull it out . paint was done 3 months ago.
LTB OLDGUY
05-05-2008, 07:40 PM #2Member
- May 2008
- Tampa Bay
- 49
alot of times just rubbing a good paste wax on them will take it out, or find a super fine compound and rub it on by hand. you could use any "clear coat safe" automotive rubbing compound you find and it would save you some money.
05-06-2008, 07:01 PM #3
hard water spots
I have used both Lime A Way and CLR with good results.
Don't leave it on the mid section and walk away. Spray it on, wait maybe 30 seconds and wipe it away with a soft wet cloth.
Repeat if needed. Heavy spoted areas may need require a longer wait time.
This will also remove any wax so re wax when you are finished.
John.Stoker 20.4 Merc 2.5
05-16-2008, 08:39 AM #4
thanks john , limeaway ! wipe on wipe off ,no more spots & paint not dulled ,looks like a black mirror again
LTB OLDGUY
