Results 1 to 12 of 12
    May 2007
    wheeling wv
    Do I need to replace the foam/1980 Baja
    I just removed the floor from my 1980 Baja and noticed the stringers were also rotted. The foam between the stringer was soaked with water even thou its been stored inside for the last 6 months. Do I need to replace the foam? I dont see how water can get to the back of the boat with the foam installed? I'm not sure if the foam adds support to my boat since the fiberglass on the bottom of the boat is very thin.
    May 2007
    wheeling wv
    Jan 2007
    Amityville/Lindenhurst
    if the boat is thin like you say it is- then put foam back.
    Dry foam does not weight anything so it wont do any harm putting
    good foam back.
    Sep 2002
    Is the hull also balsa-cored?
    May 2007
    wheeling wv
    No I dont think the hull is balsa cored.
    Mar 2004
    Brooklyn Park, MN
    i would think the foam is just for flotation. its just in the center of the boat. if it was for structure wouldnt it go all the way to the transom under the floor?
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
    Ft. Lauderdale, Fl
    That might be a cored hull. Check the transom for rot too
    Oct 2007
    North Port Florida
    Kinda looks like balsa to me, I think I can see the squares. Hard to tell from a picture, but there are no squares of different shades in fiberglass cloth or mat. If you see squares, there is core. Good luck!
    Quote Originally Posted by mrcrsr View Post
    and you could always add more hp!!
    There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
    Quinten
    86' Hydrostream Vking YT, 2.4 Bridgeport EFI
    (Rigging and interior in the works)
    88' Hydrostream Voyager, 2.4 200 Merc
    Boat of The Month Feb. 2009
    resto here, http://forums.screamandfly.com/forum...d.php?t=144414
    Dedicated to you Dad, I miss you! 1935-2008
    Caledonia Michigan
    I'm gonna have to say welcome to the club.. see where the pretty brownish turns to black, tap on the brown with a butt of a screwdriver, then tap on the black, notice a difference in the sound.
    May 2007
    wheeling wv
    The area where it turns from brown to black is just grease. The foam was covered with grease as well.
    upstate N.Y.
    IMHO,screw the foam,it's only for floatation[and waterlogging],add composite stringers if you need more stability!Nice looking ride!
    why ask me ?
  12. #12
    Jul 2007
    WV
    HEY, REMOVE THAT ENGINE AND OUTDRIVE ASSEMBLY, THEN "FIBERGLASS" OVER THE HOLE THEN BOLT ON A BIG OUTBOARD! HA HA THATS THE ONLY FIBERGLASS THAT BOAT NEEDS!
