Results 1 to 8 of 8
Thread: 78 viking help
04-20-2008, 02:47 PM #1Member
- Feb 2008
- West Michigan
- 43
78 viking help
I have a 78 vking with a 175 2.0 merc with 2:1 gears. Running 5 1/2" setback on a manual jackplate, running about 2" below the pad with a 25 cleaver on it. At about 60mph the thing starts chine walking so bad have to back out. I cant trim up much or the things a handfull. Tried racsing the motor but no help. Any help would be great!
Thanks
Jeff
04-20-2008, 02:52 PM #2
Hi Jeff,
What lower unit are you running? Does your engine have solid mounts? Also, do you have dual cable steering? That 25P cleaver is going to be too small with 2:1 gears.
04-20-2008, 02:55 PM #3Member
- Feb 2008
- West Michigan
- 43
have solid mounts and dual steering, the steering on the swivel has a little movement. Not real bad though. running about 5900 rpms pinned out.
04-20-2008, 02:56 PM #4
04-20-2008, 03:18 PM #5Member
- Feb 2008
- West Michigan
- 43
not sure on cleaver pitch, no markings on it told by prevous owner it was a 25
04-20-2008, 06:31 PM #6
I have found the cleaver to be a bad prop on a viking with 175 power. Round ear prop may be better. Do you nave a lot of seat time in a boat like this? It takes some work to counter the chinewalking. You cant just hold the steering wheel straight and hang on, you have to "rock" back and fourth a little to keep it stable. Happy boating.
04-20-2008, 06:34 PM #7Member
- Feb 2008
- West Michigan
- 43
Not too much time in it, I was thinking of running a 26 or 28 chopper. I understand the concept of countering the chinewalking, but havnt gotten it down yet.
04-20-2008, 07:49 PM #8Member
- Feb 2008
- West Michigan
- 43
Just looking at my CMC jackplate, and with the motor setup and mounting 2.5" below the pad is highest it will go. Might need to re-fab jackplate to give more lift. What is the highest I might go so I only need to make mounting brackets once?
