Results 1 to 8 of 8
Thread: Random Overheat alarm
04-13-2008, 08:32 PM #1Member
- Nov 2007
- Lake Anna Virginia
- 42
I have a 98 merc 225 EFI.... New water pump, Fresh rebuild etc. It has given me an overheat alarm a few times (within the last 80 hours of operation) it has happened during Idle, WOT, and half throttle... if I shut the boat down and wait for a little while it will go away and run great for another 2weeks or so then do it again for apparently no reason!??? Plenty of water pressure, Pees good...
Water Poppit?
Bad sensor?
Running lean sometimes?
What do you think?
Has anyone ever seen this before?
04-14-2008, 10:51 AM #27000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
check the poppet [ i think the 3.0 still have them]. that could explain all but the idle. the pee volume is not a good indicator of over all volume.
04-14-2008, 12:47 PM #3Member
- Nov 2007
- 42
poppet
I have a simons water poppet diverter.... everything seems to be ok with that... it opens up a spews all kinds of water right around 2500 -3000 rpms
04-14-2008, 12:57 PM #4Member
- Nov 2007
- 42
spark plugs
I put a new set of plugs in it and made about a 3 mile run...
Pictured is the #1 plug (on the left) and #2 plug.... the 1,3,5 side of the motor has the dry tan appearance while the 2,4,6 side has no brown and a Slightly "wetter" look
any ideas?Last edited by holata; 04-14-2008 at 03:53 PM. Reason: picture
04-15-2008, 06:01 AM #5
r u sure it is the overheat alarm.. cuz it could just be an engine alarm and u could need TPI sensors.. had it happen..
SPECIALIZED Racing 51
OPA CLASS 5 NATIONAL CHAMPIONS 07-08-09-10.. 4 TIMES OVER!!!!!
04-15-2008, 09:59 PM #6Member
- Nov 2007
- 42
does it sound the same?
it is a constant beep with no pauses
04-16-2008, 06:06 AM #7
yup.. u need to put it on a computer.. it will tell u right away what the code is.. the tpi sensors are conected to the throttle and should be right above the vapor seperator/fuel pump area.. two little square boxes that have disconects on them.. should be an inside one and outside... one for each bank.. my motor was a 99... im pretty sure u should have them.. and thats what made my alarm go off intermitently and when i shut off the engine and started it righ tback up alarm would be off.. tpi
04-16-2008, 06:06 AM #8
they arnt cheep...
