Results 1 to 15 of 19
Thread: The Sonic Chronicles
04-13-2008, 12:00 PM #1
As a lot of you know I bought my 2nd 24' twin O/B Sonic a few mnths ago.
I got screwed on the deal (another subject for another thread) and it needs way more work than advertised.
The first issue I tackled was rotted fuel lins, a fuel tank (and filters) full of scum and horrible wiring and rigging.
I pulled the floor up so I could remove the tank to clean and re-plumb it.
I reintalled it and foamed it in with 2 part foam and then glued the floor down which was not done from the factory.
The boat has a inner liner (HATE THEM!) and a molded in pocket for the fuel tank which was full of water and water logged foam due to it not having any drains
I put three 1" holes in the bottom of that pocket (liner) so it would drain to the bilge.
What I did'nt plan for was the foam while still in liquid form to run through those holes and into the bilge.
3 steps forward, one back.
Had to think on that one a while...........let's see...the floor is 63" front to rear so since I only need to drill 1/2 way from both sides that means I only need a 31 1/2" drill bit
Some time it pays to be a hill billy.
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=DSCF1769.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/DSCF1769.jpg" border="0" alt="Photobucket"></a>
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=DSCF1770.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/DSCF1770.jpg" border="0" alt="Photobucket"></a>
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=DSCF1772.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/DSCF1772.jpg" border="0" alt="Photobucket"></a>
The cabin in this one did not even have a drain like my old one did so I put one in and ran through the foam as far as I could that way and then from the bilge behind the tank.
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=DSCF1768.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/DSCF1768.jpg" border="0" alt="Photobucket"></a>
<a href="http://s290.photobucket.com/albums/ll255/Instigatorspixs/?action=view¤t=DSCF1771.jpg" target="_blank"><img src="http://i290.photobucket.com/albums/ll255/Instigatorspixs/DSCF1771.jpg" border="0" alt="Photobucket"></a>Last edited by Instigator; 04-13-2008 at 12:03 PM.
04-13-2008, 12:21 PM #2
Get-R-Dun
04-13-2008, 12:46 PM #3
Anoter use for duct tape! Did you hit oil? Bubblin Crude.....Black gold, Texas tea?
04-13-2008, 02:14 PM #4
they sell that exact same item "part #8675309" at harbor freight....
04-13-2008, 04:02 PM #55000 RPM
- Sep 2001
- KC MO
- 602
Whenever I need a longer drill bit I just weld some rod on......
CHARGER19
If you're cheap...you got the wrong hobby!
06-24-2008, 08:54 PM #6Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
Any Sonic 24 updates?
06-25-2008, 05:01 AM #7
Some..
(besides $4. per gas??)
Had boat back together and after playing with props a bit I saw 68 GPS while still chasing motor gremilns.
I have learned that the fuel pumps on the motors have resivoirs with filters that are probably partially clogged.
Runs for a few mins and shuts down.
The good though is that it ran long enough and fast enough to remind me of one of the things (besides size of cabin) I love about this boat and that is how it runs.
From about 60 up it feels very light and is a handfull to drive (which I love).
With it having a round keel it feels like you're working the wheel to keep the boat on a pad it does not have.
I have the materials to build a sun lounge and install transom knees and that will happen as soon as I work through my severe case of burn out
Once completed I will raise the motors 3", try some more props and look for mid 70's.
GaryI'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
06-25-2008, 08:26 AM #8Member
- Nov 2002
- Warwick, RI
- 63
Like Red Green said, "any tool can be the right tool"!
David H. Viau
06-25-2008, 09:54 AM #9
Gary,
What props do you have on it now.
06-25-2008, 11:23 AM #10
Well...
Greg G, heres a better link to whats going on.
http://forums.screamandfly.com/forum...hlight=started
Shad, 23 Mirgaes but going up in pitch.I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
06-25-2008, 11:54 AM #11
I got 23 Lazer 2`s, I`ve been thinking about going up or changing to different props. Let me know how it works out. If I do it first I`ll let you know.
06-26-2008, 11:17 PM #12saw 68 GPS while still chasing motor gremilns.David
______________________
2000 Powerplay Sportdeck
06-27-2008, 08:38 AM #13
I have 2.5 200`s
06-27-2008, 03:52 PM #14
Merc 3.0 225's...
06-27-2008, 05:07 PM #15Had an identical boat before this one with '99 250 JohnRudes that ran 80 dead on
I was in Florida for a couple of weeks this past March. Stayed in Fort Lauderdale, then Melbourne. I took a right along A1A up to Sebastion Inlet. It's beautiful there.
Next winter I may hit you up for a boat ride when I'm down there.David
