Results 1 to 15 of 43
Thread: Painting my Action
03-17-2008, 02:58 PM #1
Painting my Action
Hey guys just wondering, I was planning to go with white gel coat on the bottom and awlgrip on top. Is it worth adding that duratech with the gel coat? Just wondering and also what's a good primer to use. i was thinking the 545 primer from awlgrip would be best i guess.
Reaction 19ft
03-17-2008, 03:15 PM #2
1 pint of duratec to a gallon of clear, thin with a good medium paint reducer at 5 to 10%. makes it much easier to shoot, IMO.
if you are using awl-grip I would go with their epoxy primer too.> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
03-17-2008, 03:18 PM #3
so basically one pint for 1 gal of gel. You gotta see the pad now. Looks sweet. He did a really good job sanding the boat down and fixing the pad. Now you could tell its a concave pad.
Reaction 19ft
03-17-2008, 03:35 PM #4
"it was like a skateboard ramp" LMFAO!
03-17-2008, 03:35 PM #5
03-17-2008, 03:37 PM #6
Is this good info??
What sprayer/tip combinations, what pressure is required?
You can use a Gravity Feed, Siphon, Pressure Pot or Plural Component type equipment. The tip sizes vary depending on application. For Primers, use a .015-.021 with plural component equipment and for Gravity or Siphon use .070-.110 (1.8mm - 2.7mm). For Hi-Gloss, use .015-.018 with plural component equipment and for Gravity or Siphon use .060-.080 (1.5mm - 2.0 mm). Air pressure should be between 38 - 42 PSI but can be 35 - 50 PSIReaction 19ft
03-17-2008, 03:43 PM #7
yep, I use this http://www.harborfreight.com/cpi/cta...emnumber=30224
get a good gun to do the awlgrip tho.> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
03-17-2008, 03:44 PM #8
so one gun for the primer, one for gel and the other for awlgrip
Reaction 19ft
03-17-2008, 03:49 PM #9
you can use the $16 guns for the gel/primer... and a better one for the awlgrip.
03-18-2008, 03:53 PM #10
Two words:
METAL FLAKE!!!
03-19-2008, 11:11 AM #11
Any specific primer for the gel coat. should i use white or grey primer. My bottom right now is black and im planning to paint it white.
Reaction 19ft
03-19-2008, 09:25 PM #12
I thought you were going to go with a Mexican flag themed paint job, or was it a rainbow flag paint job?
I'm currently boatless
03-20-2008, 08:04 AM #13
lmao... So how are things with you and Pepe the gardener. Your wife doesnt know about the secret spot that you have right?
Reaction 19ft
03-20-2008, 09:12 PM #14Bobby Pazos- Member Of The
BULL-FROG EYES DRAG RACE TEAM
Fellow-G-Man,
Sunshine Syndicate
2006 23' Action Marine 300 HP V8
2001 19' Action Marine White Power
1998 23' Concept CC (sold)
1999 17' Action Marine (sold)
1996 STV River Rocket (sold)
04-02-2008, 07:00 PM #15
OK i have someone to paint my boat with awlgrip. He said that he is also painting the bottom with awlgrip . Is this a good or bad idea to do. He said gelcoat is not that hard to do is the sanding and buffing is the pain. ??????
Reaction 19ft
