Results 1 to 4 of 4
Thread: Bbc To Berkeley Alignment?
03-04-2008, 02:03 PM #1Member
- Jun 2006
- Plainville Ct
- 32
I have just replaced the stringers in my Sanger Super Jet and want to check for any Specs or advice before I drill the stringers for the motor mounts.
Thanks Dale
03-04-2008, 08:28 PM #2
Do you have a three point mount or 4 point mount or a rail kit 4 point set up? What drive line do you have, H bar or shaft?
03-04-2008, 08:33 PM #3Member
- Jun 2006
- Plainville Ct
- 32
Its a 4 point mount , bell housing with 2 angle brackets to the stringers and front motor plate with 2 angles . H bar i think ( 4 bolt flange 2 universals and yoke )
03-07-2008, 06:56 AM #4
With that mounting system it is most important to set the fore, aft distance so the pump shaft does not bottom out in the drive line. After you determine how far forward the motor needs to be shoot for about a 1 degree angle. This supposedly makes the needles in the U joints rotate.
