Results 16 to 30 of 39
    May 2013
    Huntiington Beach Ca
    Don't know how many Jerry made before he past in 91?
    The first Baker was my 85 with a 81 seven petal 225. It was a boat show boat and rigged with a 145 Rude. Very light layup.
    2nd boat is Delbert Teague running this 86 Baker in its first and only Enduro. He barrel rolled it at well over 100mph when a rogue boat cut the course. According to Del, Jerry Baker showed up just hours before the race with a one off deck cover. I found this boat in 2013 and now race it.
    4th is a 89 Baker Rampage we have ran the last couple Parker Enduros with. Hull weights 850lbs unrigged, 1350 in race trim minus driver and fuel. Solid ski layup and it can handle the beating.
Name:	85 baker.jpg
ID:	471104Click image for larger version.
ID:	471105Click image for larger version.
ID:	471106Click image for larger version.
  2. #17
    Dec 2010
    Binghamton, NY
    Thanks for all the great info, it’s nice to see you passion for these boats as there getting pretty rare to find.
ID:	471119 Click image for larger version.
  3. #18
    Aug 2020
    Dallas
    I have an ‘87 Baker Custom RST Open Bow. The Mercury 140 Inline 6 was toast when I bought it so I put a Suzuki DT140 on it. I haven’t run it yet but it has a 13.25x23P stainless prop on it. Any ideas what speed I can expect?
  4. #19
    May 2013
    Quote Originally Posted by Pilotryan View Post
    Post some pictures
  5. #20
    Aug 2020
    Dallas
    Standby and I will.
  6. #21
    Aug 2020
    Dallas
    Quote Originally Posted by Baker343 View Post
    Post some pictures
    Here are a couple pictures of the old setup and then the new motor mounted. When I bought the boat it had no seats or anything, taught myself the upholstery and rigging process.
ID:	472425Click image for larger version.
ID:	472426Click image for larger version.
  7. #22
    May 2013
    Congratulations on finding a Modvp hull from the pictures it looks to be in fair shape.
    Odd that it had a tower of power on it.
    Based on the railing it probably was built that way which I'm assuming Jerry made very few.
    Your current setup will probably get you in the maybe mid 50's.
    That boat probably started life with a 2.4 200.
    Looks like it still has the stock setback that Baker sold his RST with. Your Suzuki LU looks like its seen better days.
    If your going to stick with this setup make sure you have water pressure and have fun.
    If you choose to look for a bigger motor I would find a carbbed 2.5 and cut the heads for 91 CA or 92 everywhere else in Merrica.
    Put a 24 Trophy on it because it is a open bow "heaver in the bow" with a lower water pickup LU, set it around even or 1" below
    and try it. You may get into the 70's.
    It takes power and setup to make it into the 80's.
    Let us know your progress
  9. Likes Pilotryan, Mark75H liked this post
  10. #24
    Aug 2020
    Dallas
    Ok last night was the maiden voyage for the RST. She did 50 mph with a chewed up 23p prop and minimal adjustment with trim and no adjustment on the jackplate.
    I have no idea why my pictures keep loading sideways.Click image for larger version.
ID:	472599Click image for larger version.
  11. #25
    May 2013
    Sounds like your first time out was a success.
    Buy or borrow some props to find something that works for you.
    BTW nice job on the interior
  12. #26
    May 2013
    I have a openbow too.
    91 Laveycraft Seabring tunnel with a 91 200 and it will only get into the 50's but it's a solid fun family ride.
  13. Likes Pilotryan liked this post
  14. #27
    Aug 2020
    Dallas
    Looks like a very similar design to the Baker. I'm all about speed but when I have friends on board they prefer a smooth, slow ride. I'm rarely by myself. I'm probably going to try a 24p or 25p prop and see if I can make it into the high 50's.
  15. #28
    May 2001
    Hickory NC
    Pilotryan while the boat you posted photo of is a Baker it is not an RST. The RST is longer with a rounded rear deck and engine splash well.
  16. Likes Pilotryan liked this post
  17. #29
    Aug 2020
    Dallas
    Gotcha! So what does that make mine?
  18. #30
    May 2013
    I'm going to take a stab at this one and say your 18.6 Baker which I believe was built in 84 and up was a different design bottom and deck to compete with Stoker, Sleekcraft, Hydrostream, LTV's and others that don't come to mind
