Results 1 to 15 of 25
    Apr 2007
    why would one side be hotter than the other??
    what would cause a v-6 to be hotter on one side than the other
    it was pumping water good but even the water was way hot
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
    May 2005
    Greenville, NC
    Ask the guy on the ethanol thread, he seems to know it all.
    Ló fasz racing
    Joe Horvath
    Apr 2007
    ah come on
    i know more than he does
    lol
    i will change over the dumps to a t at the bottom
    so each head dumps out without a cross over hose
    for sale
    Apr 2007
    oh i just read his post
    thats not what i have
    one is hot the other is hotter
    i would quess a restriction since this motor has been down before
    for sale
    Dallas, TX
    Quote Originally Posted by jphii View Post
    LMFAO, I just owned his ass again.
    check the T-stats and make sure the cooling system is STOCK. DO NOT **** with the cooling system. there is no need.
    Apr 2007
    ok
    do we even need them here in fl
    for sale
    Dallas, TX
    Quote Originally Posted by afr View Post
    ok
    Leave it as it came from the factory. LOL. the thermostat being in the head helps it cool BETTER. it also lets the engine get to operating temp quickly.
    Here are some cooling system diagrams, make SURE it is correct, then you can diagnose it to find bad parts.
    2.0 and 2.4 I believe.
    1990 and newer
    Apr 2007
    also i cant trust the guy over at ***** he lied to me about a few things
    i just got some car plugs in there to see if it would fire up
    so the heat range maybe a little high
    perfect it is just as you put there
    which way do we turn the main shaft installing the new impeller
    is it counter clock wise
    for sale
    Ft. Lauderdale, Fl
    If I remember right, there is a service bullitien that tells you to go to the dual dump cooling system.... will look it up when I get a chance
    dumb question here: how's your water pump?
    Ft. Lauderdale, Fl
    Doesn't really matter, but the proper way is clockwise.
    Apr 2007
    it was pumping great
    now after it did fire it took a while and i had to clean out the pee hole
    i did the double dump on mine it dropped temp by half
    this is a 86
    the same thing i had back then but mine was 150
    for sale
  12. #12
    Apr 2007
    is there something i can pump threw it to clean out the water passages before i change the impeller ??
    and thermostat
    for sale
  13. #13
    Dallas, TX
    Too low of an operating temp is just as bad if not worse than too high of one. I always pulled out that little pos plastic restrictor, just because it clogged up so easy.
  14. #14
    Apr 2007
    10-4 thanks for the help
    its been a while
    clockwise good deal
    i got to get a price from bobs on the foot
    but if its going to be like 500 or more
    i will just get a new one for 800 like i want it
    i was told 800 anyways
    check on that double dump into the t for me i like the idea then and it worked great
    for sale
  15. #15
    Ft. Lauderdale, Fl
    The service bullitien was for newer motors....didn't know yours was so old.
