Results 1 to 15 of 24
01-09-2008, 02:41 AM #1
how much ?? to re do a older 200 merc
i need one built up for my hydro
the mid has to be completely re built
needs mounts tube,s the works the trim should be ok
i think it maybe a outside pump
ill have to look
i need the foot re sealed and the shaft changed to a small prop shaft
and a lw kit put on
i think all the electric is ok as far as the power head goes it turns over
and i was told its a 2.5 200
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
01-09-2008, 04:59 AM #2
All services done by others .........about 3500.00bucks .....find a 260 !!!
01-09-2008, 05:18 AM #3
scott- based on what you've done in building the hydro you should be more than capable of building the 200 yourself. Propelled Marine will have most of the parts you need. for any parts that must be mercury, I'm sure there are numerous board members that work for mercury dealers and can help you out with pricing since you are a business. just get a shop manual. take lots of digital pics prior to taking it apart, the pics and the shop manual will make reassembly much easier. assuming you don't have a lot of stuck/corroded fasteners it shouldn't be too much trouble. unless you are good at removing broken fasteners an old saltwater motor may end up just being a parts donor. basic hand tools (sockets, torque wrench, etc) and a few specialty item such as a merc flywheel puller, ring compressor, etc will make it go easier. I wouldn't go crazy trying to mod the motor, the 200 will be a great step up from the 4 cyl. bone stock rebuild with quality parts. 87 octane gas, easy on the wallet. resealing the lower isn't that difficult either.
one step at a time and you'll have it done and over with.
then you'll have one badass home grown hydro.Mike Dowling
01-09-2008, 08:10 AM #4
follow the T Rex cherry 2.4 build!!!!!!!!!
maunual........ manual........ manual
and lot of pb blaster
you built a hydo a motor will be easy!!!!!!
01-09-2008, 08:25 AM #5
01-09-2008, 04:59 PM #6
cool i can get all the dicount thru land and sea they got seara and quicksilver
so i got that coverd
im a land and sea dealer
i found out its a crome bore so you cant hone them im told
the tilt tube is broke so i got to get that first
to put it on a stand
then pop the power head off and the foot
whos got the best deal on a manual
for sale
01-09-2008, 05:05 PM #7
i don't know who told you to hone it!!! it is prob. a 2.4/200 don't hone it!!!
01-09-2008, 05:07 PM #8Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1267
- 368
I dont think you can hone a chrome bore does it need it? I thought you have to resleve them. Usually they can be cleaned if not gouged. Rick
01-09-2008, 07:09 PM #9
yes if it's chrome you need to clean it with a scotch bite pad to give it a texure so the new rings will break into there new home
finding a tilt tube should be easy to find, I would put something thru it and get started with the tear down... drop the lower off it, then once you have the power head off you can handle the pieces....clean and paint then put it all together nice clean new and ready to hang on your boat
01-09-2008, 07:32 PM #10
yep hottrucks i will try and make some progress on it this week end
i will have to see what happens
whos got a good manual on this thing
would it ba as easy as books a million
for sale
01-09-2008, 09:21 PM #11
01-09-2008, 09:33 PM #12
well i got a kinda crapy old manual from the 70,s
im not sure it is even all there
has anything changed from then to this 86 modle 2.4
shoot i dont think there was a 2.4 back in the 70,s
for sale
01-10-2008, 08:08 AM #13
looks like the cover on mine and says for V -200 just make sure that its for a 2.4..I think all the torque specs are the same and only way to put pistons in is with the Up stamped on the face of the piston at the top???
just be sure to look over the balance hose routing it looks a little scary at first but just label everything from / to Keep in mind the only person that needs to remember where stuff goes is you pic work great too..
When you take it apart a 2 liter Pepsi bottle rack ( the plastic one they use to stack them in the stores with) will be of great assistance they have 6 holes where the bottles drop into...one for each cylinder kinda works good just cover each one with a clean rag and put zip lock bags in each to hold loose bearings
01-10-2008, 05:39 PM #14
oh shoot i forgot about all the little vacuum lines and stuff
it looks like it is a horizontal reed motor to best i could tell
i should be right
i got to go by the weld shop and pick up a bar
to put in the tilt tube for now so i can get it up on my stand
first i got to put this 60 motor on there from a customers boat
then after that goes back on the boat im good
the weld shop might have time to pop me together a metal stand right quick
my shop stand is aluminum
it dont look to bad on the outside as far as corrosion goes
for sale
01-10-2008, 06:26 PM #15
