Results 1 to 8 of 8
Thread: Under Pump Drifeshaft pitting
12-16-2007, 02:48 PM #1
Are there any credible fixes for "Under the Pump Pitting " on a driveshaft ? The unit in question is a 3 Litre Sporty shaft , case number X99A002 .
12-16-2007, 03:14 PM #2
driveshaft pitting
Tom,
Do a "waterpump seals" search. There are quite a few threads on the exact problem you're facing. There are alot of fixes mentioned, ranging from rechroming to installing speedy sleeves. I had the exact problem with my 3.0l torquemaster shaft. I ended up finding a perfect used stainless steel driveshaft for $300. It seems that some other guys have had alot of luck with some of the fixes mentioned in the other threads. It seems to be a pretty common problem.
Ray
12-16-2007, 03:25 PM #3
Thanks !
12-16-2007, 03:56 PM #46000 RPM
- Sep 2002
- GREENVILLE NC
- 1,109
pitting
The speedy sleeve fix works. You can go to chicago rawhide a bearing company. most of the time they fit tightly but if they don`t some of the hi end medal type epoxies will keep it their. this fix can be done without taking shaft out at least I have sucessfully done this on a 2.5. I am told some of the smaller mercurys have a sleeve like this from the factory. I was told by Jack Barsh that they have the shafts spray welded and returned with suceess. good luck
12-16-2007, 04:05 PM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
You can find a company that "metalizes" and can build the pitted area up and take it down to correct size........( piece of cake )
Good luck,
JayJay @ JSRE
12-16-2007, 05:49 PM #65000 RPM
- Dec 2002
- Paulina, LA
- 821
I had mine spray welded with alluminum/bronze. Permanent fix.
12-16-2007, 06:31 PM #7
Speed sleeve works. Sometimes the Billet Seal Kit from MADEFI works as it uses 4 seals instead of 1 like stock. Wayne also has 20" 1 piece driveshafts at a reasonable price too. He just replaced mine.
Call him 334-874-6307 (his website madefi.com is down)
12-16-2007, 06:35 PM #8
Speedi sleeve worked for my 2.5 cle driveshaft last summer.
