Results 1 to 15 of 44
Thread: repainting possible?
12-10-2007, 03:06 PM #15000 RPM
- Apr 2004
- Montreal Canada
- 431
Need help
I have a 96 30ft Awesomecat.
The boat has the original paint & has been wet sanded & buffed.
Looks good for about a month, then it needs it again.
30ft cat., once is alot of work but having to do it every month, NO FUN!.
The problem is that I would like to leave it in the water for about a month at a time, then I pull it out,clean off the bottom & put it back in.
I live on the water & dont want to pull out every week-end.
If I repaint the boat, will I have trouble with the new paint since it sits in the water for a month.
Other option is to put graphics all over it but some of the graphics would be below the water line.
My Question: If I repaint it, will it peel from sitting in the water (month)?
If I put graphics, will it start peeling after a month.
End of story: I want it to look good, sit at my dock for about a month before I have to clean the bottom.
What would be the best thing to do.
I would graphic or paint the top & sides. The bottom still looks great & I do not want to touch the bottom.
Any advise would be great.
Thanks to all & have a great holiday season.
Jeff
12-10-2007, 04:02 PM #2Guest
- Apr 2007
- nyc
- 2,119
Sides and top you will be okay unless your in salt water. The bottom no matter how well it is painted will bubble if left in the water that long. If your going to go for a good paint job on that size boat she will run you any where from 7500 on the cheap side up 15k done right (one color nothing crazy). In the end find a way to get her out every week when your not using her, otherwise I think your throwing your money away.
12-10-2007, 04:10 PM #35000 RPM
- Apr 2004
- Montreal Canada
- 431
repainting possible
I dont mind putting the money in, but if it starts to peel
Whats the best paint to paint it with ?
Would graphics hold on the sides (under the water line)
Thanks for the help.
12-10-2007, 04:13 PM #4
I have not met anyone with a graphic wrap that isn't experiencing some peeling somewhere. You could shoot it with awlgrip for cheap and call it a day but it isn't supposed to be used below the waterline. I would be reluctant to leave it in the water. You'll end up with a blistered hull.
Get a lift!
12-10-2007, 04:15 PM #5
12-10-2007, 04:22 PM #6Guest
- Apr 2007
- nyc
- 2,119
12-10-2007, 05:46 PM #7Scream And Fly VIP
- Jan 2007
- Amityville/Lindenhurst
- 3,012
- 46
- 18
- 204
you will get a few bubbles, but it should not peel if done right
12-10-2007, 07:23 PM #86000 RPM
- May 2006
- Long Beach, NY
- 1,193
This might be a long shot, but i remember some boats using this guy called stickerdude ? They customize the boat with one huge sticker. Could work?
BOATLESS & LOOKING
12-10-2007, 07:54 PM #9
painting
HI. I think imron polyurathane enamel is the most commonly used re - paint coating on boats around here but only above waterline when boat is in the water for lengthly periods. Maybe consider having it re-jellcoated with a anti-fouling bottom possibly to color co-ordinate and you could re-apply as necessary. I myself would not have it cleared because any med. to dark color the clear bumper or dock rubs show as a whitish smudge or scratch. And if future spot in is needed it can be sanded and buffed for a better easier repair thanks.
free spirit / ONTARIO, CANADA.
12-11-2007, 10:49 AM #105000 RPM
- Apr 2004
- Montreal Canada
- 431
Repainting possible ?
Base coat clear coat.....I'm having mine painted right now. I'm using House of Kolorz, but alot of folks seem to like PPG.
Imron polyurathane or base coat clear coat
Keep in mind I only want to this once
Is these my best options & which one would be better.
I dont mind taking it out every 2 weeks., but would like to leave in the water for at least a couple of weeks, then take it out for the day for cleaning & put back in the following day.
Thanks guys, this helps with my project.
12-11-2007, 10:55 AM #11
is there a posiblity of putting in a lift???
Watch it using House of Colors I had issues with a motorcycle I painted you must use ALL HC products..the ppg primer wouldn't hold the paint when it got hot ( in the sun) it would lift from the primer..ennded up striping the hole thing and went with PPG
12-11-2007, 10:59 AM #12
Hatteras Yachts painted the bottoms of their boats for years with Imron. I doubt very many of the didn't sit in the water for extended periods of time. Makes you think, eh?
Ló fasz racing
Joe Horvath
12-11-2007, 11:45 AM #135000 RPM
- Apr 2004
- Montreal Canada
- 431
Does that mean the ppg primer is no good, but the paint is ?
Boat lift is not realy an option because the water level drops & rises all summer. Would spend more time moving the lift.
Also would have to take it out before the winter (ice).
Thanks & keep me posted.
Looking at painting, end of March.
12-11-2007, 11:53 AM #14
I have heard rumors since then of HoC being picky and it happening to others..how ever is you stay with HoC product no problem
12-11-2007, 01:25 PM #155000 RPM
- Apr 2004
- Montreal Canada
- 431
Repainting possible
HOTTRUCKS
Now I am lost, whats Hoc ?
