Results 1 to 5 of 5
    Aug 2005
    Port Ewen N.y
    I could use some help on prop selection
    I bought a 1988 21 foot Celebrity bowrider. It has a 4.3 175 hp alpha 1 drive. running at 4000 rpm range.Any prop ideas?
    Thanks
    Nelson
    Feb 2005
    seattle
    need more info. what do you have now what speed.
    May 2007
    Wright City, MO USA(Transplanted Seattlite)
    Depends on $, not quite cubic $, but enough.
    Assuming that you're still running the stock alum prop, you can upgrade to stainless, depending on the brand, and outlet, average 400
    I haven't tried a ported prop on an I/O, some ported props come with removable plugs, you could try it with and without, see if it improves your holeshot.
    The other improvement is to replace that 2 barrel carb with the Q-Jet intake and carb used on another model Merc 4.3
    Should be available at a marine salvage/recycler
    Possibly better milage at minimum cruising speed with Q-jet's smaller primaries/higher air velosity at part throttle.
    North Tonawanda, NY
    I set one of these up years back.....
    ...had good top end but no hole shot, even pulling one skier was near impossible. The fix was to swap to a Land and Sea Torque Shift variable pitch prop- top end remained the same, but the boat could now easily pull up 2 skiers with 3 people in the boat. The bad news is that the prop isn't available anymore and was a PIA to get working right.
    Doug
    Nov 2002
    South Carolina
    I think I still have a quicksilver torque shift prop.
    Let me know if you are interested.
