Results 1 to 15 of 35
Thread: garage lighting
08-08-2007, 07:57 PM #1
garage lighting
Hi,
I was just wonder what everyone has for lighting in their garages. I detail my vehicles often and have found that different types of light show different defects in paint.
i am thinking i am going to hang some florescents along with some standard incandescents and then some halogen spots, all seperatly switched. along with a couple wall mounted flourescents tooJohn E.
HydroStream Vandal 140 EVINRUDE 69mph GPS
Black'99 SVT Lightning #1767 of 4000
If It Ain't Blown It Sucks!
08-09-2007, 08:15 AM #25000 RPM
- May 2001
- Brookfield,Wi
- 225
Chynewalker, I have a 3 car garage and I used 3, 8' fluorescents and when I detail I pull out the twin 500 watt halogen lamp. It shows any and all swirls and scratches. If I was building it over again I would have added several built in can lights also.
08-09-2007, 08:49 PM #3
i just bought the house and it has a 2-1/2 car garage and it has only 1 bulb in the middle . so i have a clean slate to work from
John E.
08-22-2007, 03:47 PM #4Member
- Sep 2005
- 49
with the fluorescents, go to a electrical wholesale house and get color corrected bulbs ( tell them you do detail work and want light color as if outdoors in the sun) they will cost more but are worth the cost for the quality of the light
08-22-2007, 07:52 PM #5
If it was me I would get a few hid lights. They may not be color corrected but they aren't the ugly colors anymore either.
Preheat is a problem, so fluorescent or bulbs are still needed. But when your out a while nice amount of light output.
I think the only type that come close to the right color temp are sodiums.
I did get a brain fart last week. I'm going to convert one of my dual tube shop fluorescents into a trouble light. 4' of light will cooly light anything I'm going to need a trouble light for.
Under the deck with a 250w halogen isn't nice on hot days.'90 STV
'96 260
under construction
for far too long
08-22-2007, 08:07 PM #6
I would go with metal halide bulbs in a 8k to 10k color temp and use electric ballast so there is a 10 - 20 sec warmup time.
you can use 3 250w for a 2 car garage and it will look like daylight < no joke
I make metal halide lighting system for aquariums on the side trust me there is no lighting on the planet in this price range that comes close
08-24-2007, 10:14 AM #77000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
you need the flor in the longest length you can get usually 8'. the longer the length the more light you'll get at any point. just one of theose laws of phyics.
08-24-2007, 11:01 AM #8Scream And Fly VIP
- Mar 2004
- Tulsa, Oklahoma
- 451
that's a great idea about color corrected fuorescents, I have never heard of them.. off to the electrical wholesale house for me..
08-24-2007, 10:20 PM #9
i have colored florescents in my fish tank and they are very bright and really bring out the colors in fish. hmmm:
John E.
01-02-2008, 02:14 PM #105000 RPM
- Feb 2004
- massachusetts
- 381
the flour lamps they are talking about do not really cost anymore, just may not be able to find them at your local home improvement, order them at any electrical supply house or from grainger etc...
you want what they call "daylight" 5000k on the spectrum, look for a quality bulb that retains it's color and brightness over time, that is the major difference in quality, they all look good for a few hundred hours but drastically loose output and color quality over time
I would def use a couple extra lights,they are short money, $50.00 or so per fixture for an 8' flourecent strip light using 4-4' lamps, you want a good overlap of light, you can always switch them seperately so it is not always lit up for detail type workLast edited by markt111; 01-02-2008 at 02:18 PM.
01-02-2008, 02:18 PM #115000 RPM
- Feb 2004
- massachusetts
- 381
nothing againds HID, they are very efficient just don't seem to fit the application in most home garages unless you have a high ceiling and the initial expense is obviously greater
also if your garage is cold (depending on climate/heat etc..) make sure whatever you get is rated for the temperature or you will have starting problems, most electronic ballast these days are good down to 0*F
01-02-2008, 02:45 PM #12
I have 8.... eight foot floresent if i had to do it over I would mount them on the wall my garage is 24 X 28 I think the light is better more of a piant shop style
01-11-2008, 07:44 PM #13
get a 3 wick candle !
dont ever use apple drywall company on long island , they suck !!!!!!
03-13-2008, 03:16 AM #14Member
- Aug 2003
- Oregon
- 40
In my garage I have about 20 20w compact fluourescent bulbs strung around. They're usually on sale for only a buck, and seem to last a lot longer than the long tubes. And they're much easier to throw away when they burn out.
03-13-2008, 06:27 AM #15
thats alot of little bulbs
John E.
