Results 1 to 4 of 4
Thread: 1998 Merc 200 Efi
08-06-2007, 02:57 PM #1Member
- Aug 2007
- Northern IL
- 39
1998 Merc 200 Efi Prop Help
I was looking for some input on a prop and rpm for this motor. Right now it is on a 21 foot fish and ski boat with a 26P 4 blade prop and I get about 5200 rpm @WOT and in about 57 MPH on the GPS with only me and baout 1/2 fuel. This does not seem right to me. Is it? Let me know your thoughts.
Thanks BrianLast edited by fisher200; 08-07-2007 at 01:08 PM. Reason: Prop help
08-06-2007, 07:21 PM #2Member
- Mar 2007
- Aurora, Mo.
- 72
go down in pitch. probably a 24p of the same style prop should get you close with a good holeshot as well
1984 Champion 184DC 1984 Mercury 200 2.4l w/some mods
08-07-2007, 01:06 PM #3Member
- Aug 2007
- Northern IL
- 39
Thank you I will see if I can borrow a prop to try it out.
08-07-2007, 02:11 PM #47000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
if you going to be skiing you may want a 22. hy HS voyager use a 23 for speed and ski. it turn up to 6300 depending on the JP heigth. you need to keepit under the RPM for the oil injection and pastic bearing carriers. you shold be using a 4 or 5 blade prop se well.
