Results 1 to 3 of 3
    May 2007
    Low RPM, Vibration
    I have a 2001 Islandia, 240 Merc EFI. The RPM's won't go above 4900-5000 RPM's. I did a compression check and all were around 130 psi. Next, I would like to verify all cylinders are firing. What's the easiest way to do this? If 1 or more aren't running, how do I tell which ones? Any other ideas or suggestions regarding this problem are appreciated.
    Also at idle to about 1500 RPM's the engine is extremely rough. Very shaky like a cam with a lot of overlap in a car. So if all the cylinders are firing, maybe something else is off balance like a bad impeller? Would this also slow the engine and boat down?
    Thanks,
    James
    Aug 2004
    Hillsboro MO
    Most likely not an impeller or pump issue. I'd focus on an eng malfunction. Post your question in the Tech forum..Good luck!
    May 2007
    Thanks for your reply. I posted in the Tech forum also.
    James
