Results 1 to 15 of 16
07-01-2007, 09:54 PM #1
*** Cracked or repaired lower units NOT permitted for sale here ***
Here's the deal everyone - regardless of which end of the debate you find yourself on this issue, lower units that are cracked or repaired at the skeg any other stress point are not permitted for sale on Scream And Fly.
So, to be clear:
Modified Sportmaster (within reason)? OK
Repaired anti-cavitation plate? OK
Cracked or repaired skeg? NOT OK
Those units are dangerous and should either be used on slow fishing boats or scrapped.
Thanks,
07-01-2007, 10:35 PM #2
Thanks Greg Keep This At The Top....i Gotta Friend The Bought 1 And The Guy Didnt Say Anything But I Noticed It Had A Skeg Welded On He Was About 2 Put It On His Alli And Run 100+mph... He Might Not B Here Otherwise .... Peaple Just B Honest And Dont Kill No 1.......thanks Todd
Quit Hate'n and go test.
07-01-2007, 10:42 PM #35000 RPM
- Apr 2007
- Big Pine Key, Fl
- 414
- 13
- 21
- 45
- 107
Welded skegs
I have first hand knowledge of what happens when a welded skeg lets go.I bought a Lower unit that I knew had been repaired { by a good welder}it was sweet.The first time I ran the gear case was at the high speed shoot out in north FL..I was going up river after a 100 + pass and I got into it again....about 70 mph the boat hooked left hard and pitched my buddy[ mach 351 on the boards] who was in the back seat about 30 ft into the river.HE was wearing a vest thank God ......My point is there was no warning and if there was another boat on the left or the right the out come would have been very very nasty......never again I will use a welded on skeg..
tcampbelljr@comcast.net liked this post
07-05-2007, 07:41 AM #4
What about twin engine applications with no torque tab?
07-06-2007, 11:04 AM #5
school me
I have a sportmaster that hit a chain, and took out a chunk of the skeg. not much though. The torque tab is still there, around the bottom of the shaft housing the skeg is still original. just at the bottom corner where it hit the chain does it have repair work. I'm running it on a 280 powered XB2002. have made countless high 90, and numerous 100+ passes. Am I just lucky nothing bad has happened yet, or do I have enough of the original skeg to be in the clear?
07-06-2007, 11:38 AM #65000 RPM
- Apr 2007
- Big Pine Key, Fl
- 414
- 13
- 21
- 45
- 107
skeg
My gear case was repaired at the bottom of the houseing so when the skeg came off the boat lost directional control[A BLOWOUT]. I also have a sportmaster with a repair on the botton leading edge of the skeg...the repair was the size of half dollar and I have had no issues with it after many 100 mph passes. IT sounds like your case repair is ok .I think Greg meant lower units that the skegs were repaired or replaced or cracked up close to the houseing because when the repair fails it becomes deadly to the people in the boat and any thing within 50ft around the blowout.
07-06-2007, 01:19 PM #7
Thanks!
05-03-2010, 10:49 PM #8Member
- Aug 2009
- Brainerd mn
- 31
I have repaired quite a few broken skegs. If two angles are used instead of prepping a straight angle I believe there is far less chance of the skeg coming off again. Maybe I have been lucky, maybe Im just good have'nt had one come off after I fixed it.
05-03-2010, 10:59 PM #9Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,737
- 102
- 115
- 1556
- 514
God, Country, and Fast Boats
05-04-2010, 09:24 AM #10Member
- Aug 2009
- Brainerd mn
- 31
Im just sayin that they can be fixed if you know your stuff. I dont have one for sale. I fixed a sporty last year on a over 100 mph boat. and its still running. no propblems.
05-04-2010, 09:31 AM #11
Rules is rules....
I have always wondered about those slip on skegs, skeg guards. How do they hold up? If I were to do one I would fill it with epoxy before installing it. Just a question.Don't lick my boat, It makes it sticky!
Another Hitman for the Sunshine Syndicate!!
2011 Seafox Viper
05-04-2010, 09:46 AM #12
Here's the thing............. I believe it's IMPOSSIBLE to weld a skeg back to STRONGER than new condition, and as cast ones fail. When a skeg comes off they CAN cause serious injury or death. I think it is an absolutely foolhearty gamble to run a welded skeg on a high perf/high transom height boat regardless of how good you or anybody elss THINKS they are. In any case, we don't allow them sold here OR offers to repair either.
05-04-2010, 09:50 AM #13
Jay I believe the slip ons are well suited for low perf boats that have had skeg damage from striking something. Skegs fail from high torque applications at the rear near the top and the crack works foward from there. A slip on or skeg guard does nothing to strengthen this area and I would guess could even add to the potential for failure if somebody runs it high.
I know of an STV doing a bat turn only running about 60 when it came off. Obviously it was already cracked. I can't imagine what would've happened at 100 plus.Membership upgrade options: http://www.screamandfly.com/payments.php
05-04-2010, 09:59 AM #14> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
05-04-2010, 10:00 AM #15
Thanks raceman, I was wondering cause you always see skegs with a chunk out the bottom. The repair I described would only work on a boat with the top half of the skeg intact.
As for welded skegs. I second your comment on it being a gamble, with someone elses life no less. Also, I have a friend who is a pro welder. He has to have his skills tested periodically with hydraulic presses for breaking strength and x rayed. If there is anyone in the world I would trust my life to their welds its him. And he refuses to weld cast aluminum where someones life could be on the line. He races motorcycles, and I got my hands on a wrecked one for him and told him it just cracked along a weld and he could have it free and repair it. He took one look and said it wasn't worth risking his life over welding that, turned out to be a cast frame. Just food for thought.Don't lick my boat, It makes it sticky!
2011 Seafox Viper
