Results 1 to 15 of 17
Thread: mirage wildcat
06-13-2007, 11:00 AM #1
mirage wildcat
need some help, does anybody have any information on the mirage wildcat? like weight or any history of the boat will be appreciated. thanks kevin
"Smith Bend Racing"
95 S.T.V. River Rocket/2.5 merc
06-13-2007, 11:26 AM #2
Modvp22
Where ya at!.....MODVP should know about it. I asked him the same questions a while back but all the alcohol has made me forget and I don't wanna misquote ya!
Smith's Bend Scoundrel
'88/'11 Reaction 19, '88 Merc 200 "Jus' Toodlin'"
'83 Hydrostream Varmint, '88 Merc 200 "Jus Triflin'"
06-13-2007, 02:19 PM #3
Wildcat
What do you want to know? I have a Polecat, qnd my buddy races a Wildcat,
Rick"Conklin Racing" M/E 0494
Sponsers,Conklin Racing, Speed-N-Sport Marine
06-13-2007, 02:33 PM #4
whats the weight on the wildcat? were there not many of them made? i'm jus wonderin a little general information about them.
"Smith Bend Racing"
06-13-2007, 02:46 PM #5
nobody i've talked to can tell me much bout them except that there light and a pretty good drag boat
"Smith Bend Racing"
06-13-2007, 05:35 PM #6
Wildcat`
I believe most of them weighed in the 500# range pretty light, they are good drag boats but have a bad reputation for blowing over which is what caused them to be banned in some associations back in the early mid 90's. The pad is ABOVE the sponsons which makes it a true tunnel instead of a mod tunnel, the tunnels are very shallow which makes it accelerate quickly. The boat in my opinion is not safe above 115 mph!!! Just my opinion but it has a tendency above that with the shallow tunnels to not slow down gradually when you get out of the throttle, it tends to not release air and then all of a sudden it releases the back end drops and the nose comes up thus causing a blow over. Below 115 it doesn;t seem to have that problem.
I'd be happy to talk to you if you'd like
06-13-2007, 05:47 PM #7
Here is a pic of me drag racing against one.This was guy named Pete's boat.He blew it over about a year after this pic was taken at Eustis Florida.Got pretty banged up and I dont think he ever raced again after that.
This boat was super fast in the 1/4 mile.I beleive this boat belongs to Greg Moss.I could never beat him.Just be carefull if you get one.
Rob Lankford
1988 20' Action Marine 2.4 200
Previous owned boats worth mentioning
1976 17' Action Marine 2.4 200
1984 20' Action Marine 2.5 200
1983 17' Hydrostream V-King 2.4 Bridgeport
2003 LPB STV RR COPY 2.5 280 /300 Drag
2005 LPB STV RR COPY 2.5 280
2005 Baja 23 Outlaw 6.2 Mercruiser
2006 FTP Quarter Shot T3 Race 2.5 200 CARB/2.5 225 PROMAX
2009 FTP Quarter Shot T3 Race 2.5 280
06-13-2007, 08:28 PM #87000 RPM
- Houston Tx
- 2,286
Yep I own it now
There is a difference in this boat to another Wildcat. Mine has a pad added to it so the center pod is below the sponsons more like a Polecat. The boat runs very well and very controllable. http://www.byuboyz.com/forums/showthread.php?t=16112 I have alot of pictures here.
06-13-2007, 09:23 PM #9
Wildcat/Polecat
Greg is right the Polecat has the pad dropped below the sponsons just a little bit, mine runs very sweet and is predictable and stable up to 115!!! I won't take it any faster!!!
I wanted to go faster so I have bought a Quartershot T-1 and have already run it 117 in the 1/4
06-13-2007, 09:24 PM #10
Wildcat/Polecat
06-14-2007, 06:03 AM #11
I can see why the guy in the first pic went over. Most tunnel type boat`s will blow over at that angle when at top speed. If you get a Wild Cat please don`t run it that high.
DB
06-14-2007, 08:49 AM #12
thanks for all the replys, they are all very helpful.
kevin"Smith Bend Racing"
06-14-2007, 01:41 PM #13
I used to watch Barry, RL and Jodie run very fast wildcats in SLDBA 10yrs ago or so.
Rick, was the boat Lloyd was in a wildcat or polecat?
Thanks,Jason
Outboard Junkie
06-14-2007, 08:53 PM #14
Lloyd
Neither he was in one of the lightest Jauguars ever built.
06-14-2007, 09:40 PM #15Supporting Vendor
- 11,838
- 163
- 11
- 795
I won 1400 LBS Modified World and High Points Championships in a Mirage Polecat... A Polecat is a Wilcat with a 1 1/4" deeper center pod "scabbed" on the center pod. There was NO SUCH thing as a Polecat mold . I was sponcered by Brad Collins at the time the Polecat and Wildcat were popular and saw every mold they were using.The Wildcat was difficult to drive, it was a straight line tracker but over 80 miles an hour was resistant in turning. It also had VERY shallow tunnels and as long as the MPH was kept below say 112 to 115 and the motor kept running and the trim angle of the engine kept resistants on the front your were OK BUT above that speed or you loose a motor and the push downward of the engine was lost the front would lift and the air channels would be cut off due to thier shallow deminsions and over your going ( Ask RL about a Wildcat ).... After Brad "scabbed" on a 1 1/4" lower step on the center pod of my hull the boat took on a different additude and was safe and a joy to drive...It could be driven very flat and would not only leave like a tunnel but would run on the big end with the Allisons...( Been there and done it ) ( Ah the good old days ! )
Good luck,Jay @ JSRE
