Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 76
  1. #31
    Dallas, TX
    Quote Originally Posted by UP_ROKTOY View Post
    In the front I just undid the torsion bars until the truck was on the ground. Got an alignment and called it good,
    thats what we told him to do but it made too much sense? lol I WISH my TBSS was that easy to lower.
  2. #32
    Nov 2004
    LEBANON OREGON
    you can make an edge a std 4x4 just by loostening the tensioners as MANY of us have said.... look where the bars mount in the frame at around the T case... you will see 2 roughly 3/4" headed bolts.... just back them out about 2/3s of the way and you will drop the truck 3 inches... remove block and you are good to go.
  3. #33
    Nov 2004
    LEBANON OREGON
    Quote Originally Posted by 1BadAction View Post
    : I WISH my TBSS was that easy to lower.
    got yer gas axe..... ya can lower anything..
  4. #34
    May 2005
    Winter haven fl
    man im happy im not in your shoes
    The lowering kit I found has new control arms , spindles , coils , leafs , and high compression shocks quite a deal at $ 510.00 . at any of the following drops 4-5-6
    LASER LTV - common sense is the key to success .....not many people succeed these days . ROBERT S. FEAGLE
  5. #35
    May 2005
    Winter haven fl
    But all yea I drive a chevy
  6. #36
    Dallas, TX
    Quote Originally Posted by 150aintenuff View Post
    not with airbag springs in the rear besides, hot springs are for spas and white monkeys in the snow, not trucks
  7. #37
    Nov 2004
    LEBANON OREGON
    Quote Originally Posted by WATERWINGS View Post
    Growing up on a Saw Mill, I have ridden/driven many, but I'm sure ours were much older and pieced together than any of the nicer/newer ones.
    the bad ones have pad suspension... its cheep but it aint winnin ove any smooh ride contests...
  8. #38
    Nov 2004
    LEBANON OREGON
    move the brackets... not real hard...
  9. #39
    WASHINGTON N.C.. I TOO HAVE A BOATING PROBLEM
    ....for the front, just take the adjustment bolt clean out for the torsion bars and go get an alignemtn
    I can take the adj. bolt COMPLETELY out?
    3" of drop by cranking out 2/3 of the bolt?............ GROOVY
    Cool, it sounds almost to good to be true.
    Thanks ya'll, I know I sound hard headed, but I wanted to hear as many ideas and angles as I could get.........
    jphii........I STILL may put a Trophy on it
    Once again, Thanks to all who put up with my thick sculled knuckleheaded self.
    JOHN MASON
    '83/VECTOR/MERC 200-- SOLD
    '98 Quartershot T-3/ MERC 200
    "If your not living on the edge, your taking up to much space"
  10. #40
    Dallas, TX
    Quote Originally Posted by N"the rigger"partin
    yea thats it, even if there was room to slide the brackets up 3" im going to cut up a brand new vehicles frame with a torch like a moron ricer. please do yourself and others a favor and never work on anything mechanical.
  11. #41
    Nov 2004
    LEBANON OREGON
    you can take the bolt all the way out.. but then you risk loosing all tension if the keepers fall out so leave it in atleast the length of the diameter of the bolt...
  12. #42
    Nov 2004
    LEBANON OREGON
    1 bad.... you arent cutting the frame... just the botom bracket and replacing it with a longer one dropping down below the axle... effectively bringing up your axle and lowering the truck... it has nothing to do with a moron ricer.. when kits arent available those Who want one BUILD it theirself.... dont you work on a CNC machine...... built youself a set of dropped mounts and weld them to the axle..
  13. #43
    Dallas, TX
    they are airbags, you cant move the mount on the axle... besides buying 3" shorter bags is easier than cutting steel apart. lol.
  14. #44
    Nov 2004
    LEBANON OREGON
    airbags have to mount in a cup on the axle... move that cup forward. mounted on the bottom of the axle it isnt hard.. and it would be cheeper to do as well than 2 new shorter air bags...
  15. #45
    Dallas, TX
    you're fukking delusional and clueless. to make that work I would need to relocate both top AND bottom mounts. the bag mount is directly on top of the axle.
    next you are going to tell me the paint is red not blue
